Will OBX LT's + ROR = deafness?
Old Apr 24, 2011 | 09:23 PM
  #46
Good pic Darren
Old Apr 24, 2011 | 09:58 PM
  #47
Did find this wonderful install guide on the Dynatech site.
http://www.dynatechheaders.com/instr...o08_2WD4WD.pdf
Old Apr 26, 2011 | 12:09 AM
  #48
ParnAZ's Avatar
You will NOT be dissappointed ....The wife still asks me why I always want to drive my truck over her car when we go out.
Oh and I HIGHLY suggest re-tapping the threads on the block and cleaning them out. GL
Old Apr 26, 2011 | 06:45 AM
  #49
FATHERFORD's Avatar
nifty install guide, ill add that to my f150 longtube guide...
also just a side note... With the correct extension, rachet, and socket the starter is SUPER easy to remove. I wish I wrote down and measured which combo I used as you only have about 1" of play to fool around with....
Old Apr 26, 2011 | 11:01 PM
  #50
Patrick is going to do the install for me and I believe he did the starter trick on a prior header install. Good to have trustworthy friends to help with this stuff.
Old Apr 27, 2011 | 10:28 PM
  #51
OK, OBX LT headers w/cats, locking bolts, and O2 extensions ordered.
I decided to go with extensions rather than extending the wires myself or going with longer O2's. I know people on either side will argue with my decision but after all the research I feel comfortable that the extensions will work fine. If not then I know the alternative.
I think my neighbors are going to hate their 5:30am wakeup call every morning.
Old Apr 27, 2011 | 10:32 PM
  #52
I want to hear this!
How's it sound on there... you're done yet right?
Old Apr 27, 2011 | 10:35 PM
  #53
I have a slight exhaust manifold leak. I still have the stock exhaust manifolds. Not throwing any codes, but I do have inspection coming up next month. :o
So, I've been contemplating getting OBX LT's with high flow cats for a while now. Thing is I have the rear exit ROR exhaust. Sounds great.
My question is if I add the LT's to the ROR, will my exhaust be too loud? I'm thinking it won't be when I'm cruising, which is what I do most of the time, highway miles.
Thoughts?
Also, fill me in on the O2 extension deal. How many? Easily made, or easier to buy?
Thanks, all.
I think you'll be happy with your decision....good luck!
  #54
As long as it doesn't drone on me while driving normally I'm not going to be altering the ROR catback. If and when I do put on my 3DCarbon skirt kit I'll have to re-do the catback to a side exit and sell the ROR exhaust.
Old Apr 27, 2011 | 10:39 PM
  #55
One more tidbit....
Have you talked to Bill@PHP about rewriting your strategy?
With the new O2 locations the transfer function will be slightly altered.....
Old Apr 27, 2011 | 10:42 PM
  #56
Originally Posted by 88racing
One more tidbit....
I may have to have the tunes altered. From Bill:
William,
Long-Tube Headers historically will cause a slightly lean condition due to the improved scavenging of the cylinders and subsequent (small) rise in volumentric efficiency. Looking at your existing tunes I really don't think there would be a problem, but considering that you're combined with high flow cats you might want to go ahead and have some minor tweaking done on the files just to keep things safe.
I hope this is helpful.
Bill Cohron
Power Hungry Performance
Old Apr 28, 2011 | 12:44 AM
  #57
IR0NS1N's Avatar
I did long tubes on stock Whipple tune. Didnt change **** on my wideband or on my short term/long term fuel trims
Old Apr 28, 2011 | 03:46 AM
  #58
jbrew's Avatar
Yea, I'm not sure what needs to be changed adding LT's, - It's not even worth messing with IMO, -specially if you've already been tuned for an intake. I believe Mike has mentioned that somewhere.
Personally, I'd also purchase O2's that fit the install, but to each his own. Yea,-Screw all those connections, -the less the better.
Old Apr 28, 2011 | 05:46 AM
  #59
Yeah, I'm fairly comfortable with the custom tunes the way they are since Bill thinks they are fine. But I have to hand it to him, he's a good businessman. He put in there just enough to make me possibly want more tunes.
If the extensions give me a code or whatnot I'll get different O2's.
Old Apr 28, 2011 | 05:10 PM
  #60
jbrew's Avatar
Yea, if you get any kind of 02 DTC's inspect the connectors first. Even new connectors can thro a DTC. Depending upon construction, the connector can be packed with that white factory dielectric. It's added into the back of the connector then a silicon plug is pushed into it for weather seal.
This is good unless to much is added and contaminates the majority of the connector pin. O2 wires/pins are sensitive.
Other than that and most likely, it's plug and play.
