what is beter flowmaster or magnaflow or what?
Old May 3, 2010 | 05:33 AM
jamesmitchell's Avatar
i dont know what would be better i want it to sound good but not to loud
Old May 3, 2010 | 06:28 AM
MGDfan's Avatar
Hello & welcome.
Both Fartmaster & Magnaflow offer very loud variants, and each has it's own unique, very personal and subjectively appreciated sound. What is considered 'drone' to some is music to others ...
Generally speaking, the larger the internal volume of the muffler canister, the quieter it is ...
I will offer this in terms of a performance perspective, though ... excerpted from this post: https://www.f150online.com/forums/1754796-post2.html
Originally Posted by Superchips_Distributor
Hi Trriton 2,
... Though it's not an absolute must, yes, we do recommend getting rid of the "Slowmaster" muffler and replacing it with an appropriate Magnaflow unit - that will help to improve torque. Now exactly which muffler you use will depend on what kind of sound characteristics you want, so that's why you need to call, so we can go over all of that with you. It's not just length alone, for example.
What that Flowmaster setup is doing is actually *reducing* torque on part throttle at any rpm, and reducing torque below about 3000 rpm a at any throttle position - and that is due to all those silly baffles & chambers they use as part of their "sound engineering" - all they are is impediments to airflow, and slow down exhaust gas velocity, which is why you don't see much in the way of HP gains form them, and actually lose torque, especially in the lower rpm ranges. When it comes to torque, exhaust gas *velocity* is absolutely key. ...
You decide
Good luck!
MGD v5.0
Old May 3, 2010 | 07:00 AM
mrshadetree0222's Avatar
Originally Posted by MGDfan
Hello & welcome.
You decide
Good luck!
MGD v5.0
I will be following this thread as I too am in question on what to do with my exhaust situation as i am going to have to remove the tailpipe in order to install a trailer hitch on my truck!
And the more I think about it I am liking the super quiet exhaust sound, Its nice to be able to hear my own brain think! But then again_on the other hand I want to hear the roar of the monster under the hood!
Old May 3, 2010 | 08:36 AM
4.6 Punisher's Avatar
Magnaflow
Slowmaster sounds like ****, IMO.
Old May 3, 2010 | 09:40 AM
Veteran: Army
magnaslow sounds like poop on a stick (minus the stick) at any RPM, sure on the dyno sheets it shows like 3 hp over the slowmaster when revved to 6000 + rpms
on the same dyno sheets the borla xr-1 and xs pro mufflers out performed all the other brands but the magnaflow following is huge on this forum and what you'll see shortly when that's the #1 brand you are told to use
honestly, you need to get on you tube and watch sound clips (I know internet sucks compared to real life where you feel and hear the exhaust sounds) and then once you find a truck you like the soudn of you can copy that exhaust
Old May 3, 2010 | 09:45 AM
mxracer49's Avatar
What truck is it going on? 04+ 5.4 MBRP SI/SO sounds excellent and you can't beat the price for a full cat back system, stainless, mandrel bent with tip for around $350 shipped.
Old May 3, 2010 | 09:49 AM
MGDfan's Avatar
Took the resident Borla guy long enough to show up
I can see clear through either of them -
Besides, can't afford Borla in Canuckistan
MGD v5.0
Old May 3, 2010 | 10:24 AM
FATHERFORD's Avatar
pshhh
my Magnaflow dominated Borla 2-1 in national taste test.
Old May 3, 2010 | 10:35 AM
Veteran: Army
Old May 3, 2010 | 11:36 AM
2low2slow's Avatar
Borla guy here
I've got some videos on the site and I'm going to try to get some more when I get back home.
Old May 3, 2010 | 11:57 AM
Borla's are sexy... Kinda want to do one next year not gonna lie... maybe a s type idk.
Either way go with what you think sounds good.
Old May 3, 2010 | 04:09 PM
Magnaflow hands dont when compared to Flowmaster's junk.
Borla is the king though, t-304 stainless and a rich note, cant go wrong.
Old May 3, 2010 | 04:16 PM
TampaWright's Avatar
having had both brands I say magnaflow has a better tone, doesn't cause low end loss, doesn't rust out... and is cheaper. Really no comparison
Old May 3, 2010 | 04:57 PM
rllackey28's Avatar
Agreed. If all you are going to change is the exhaust itself you should go with the sound you like best because you will be hard pressed to notice the "losses", but that's just my opinion based on my own MBRP and Flowmaster experiences.
Old May 3, 2010 | 10:25 PM
avfrog's Avatar
Borla!!!
