Magnaflow 94106 questions.....
Old Jan 17, 2010 | 09:09 PM
  #46
08FX4's Avatar
Here is a somewhat decent link to what mine sounds like now (you'll have to excuse my wife...... she thought she was being funny ):
http://www.youtube.com/watch?v=iml_KfMwG7U
http://www.youtube.com/watch?v=9TXDX8XBGRI
Old Jan 17, 2010 | 09:21 PM
  #47
I've always wanted to here mine... I think mine is deeper and a bit louder tho.
Old Jan 17, 2010 | 09:28 PM
  #48
08FX4's Avatar
How many miles is on yours?
From the inside it sounds fairly loud, very deep, and mean as hell. Once you listen to it on the outside it doesn't seem as loud as it should be. If you've never listened to yours on the outside with someone else driving you would probably see what I'm talking about. What's even more odd is the fact that you have an '04 which has 4 cats. Mine is an '08 and only has 2 cats.
I think a lot of sound is "compromised" when recording unless you have an extremely high quality camcorder. I was using a Sony DCR-SR47 which is just a basic camcorder for the "every once in awhile" user.
However...... it still should give a pretty good example of how going to high flows will affect the sound.
Old Jan 17, 2010 | 09:30 PM
  #49
08FX4's Avatar
By the way...... the first run was up to about 3000 RPMs and the second was WOT.
Old Jan 17, 2010 | 09:40 PM
  #50
I think I have about 5k or so on it. I agree, the inside sounds good, but I want it a bit louder in there. Nothing crazy, which is why I am really anxious to hear yours with the maggie hi flows. The outside should def be louder tho.
Old Jan 17, 2010 | 09:48 PM
  #51
08FX4's Avatar
I'm ready to hear it too!
I've probably got 5K on mine as well. Let me get the inside video up and you can compare that to yours......
Old Jan 17, 2010 | 09:55 PM
  #52
Sounds good man. Ill let you know once its up!
Old Jan 17, 2010 | 10:11 PM
  #53
08FX4's Avatar
I put the video in the post above. The camera tried to focus in on my steering wheel but you get the point. Oh yeah..... I "terminated" the WOT run there at the end once I seen the officer sitting behind some trees. I'm not sure why he was there -- I turned down a deserted road to make this video!
I'm hoping the high-flows give me the sound I'm looking for but if they don't I'll be deciding between true-dual bullets (like mblouir), true-dual magnapacks (like 4.6punisher), or true-dual 11" body magnaflows like Darrens (except with high-flows). If I do change I've decided I want to stick with a straight through muffler. I really like the "rumble" that true-duals give you but I also like the deep tone of 3" pipe and a SI/DO muffler. I'm at a loss I guess. Let's just hope the high-flows sound like we want them to!
Old Jan 17, 2010 | 10:17 PM
  #54
Sounds very close to mine, although you accelerate harder than me, so mine is not always that loud inside. I don't usually go over 2k. Sounds close to me, how far back is your muffler mounted?
Old Jan 17, 2010 | 10:22 PM
  #55
08FX4's Avatar
I don't normally accelerate like that either. Most of the time I try to keep it below 2.5k max unless I have to.
Mine is mounted just in front of the front leaf spring bolt. I used the 3" mid-pipe from a Banks kit so it's mounted the same place as most cat-back systems. How about yours?
Old Jan 17, 2010 | 10:35 PM
  #56
Mine is upgraded to 3" partway down the mid pipe and is a 3" dual 2.5" out. The muffler is right before the axle.
Old Jan 18, 2010 | 12:23 PM
  #57
That white FX4 sounds god. Thats yours? Sounds very nice for stock cats!
My exhaust has 21k miles through it and I highly enjoy hearing when its driven off
Old Jan 18, 2010 | 02:54 PM
  #58
08FX4's Avatar
Yep that's mine. Thanks! Hopefully the high-flows will really open it up!
Old Jan 18, 2010 | 02:56 PM
  #59
I hope so! As long as the increase is mostly outside, Ill jump on the bandwagon. I don't want crazy drone.
Old Jan 18, 2010 | 03:45 PM
  #60
4.6 Punisher's Avatar
I really liked that high RPM pass you made, very smooth. You're not going to be disappointed with the hi-flows!
