True Duels = Loss of idle rpms ?
After I put my duel cherry Bombs on I had a Cat. crap out two days later. I have now replaced both cats with High Flow Magnaflow"s. I am now at an idle of about 500rpm. which sounds like crap. Also now with the high flows I can't belive how loud they are. ( to Loud ). Now I am thinking of replacing the cherry bombs with MAgnaflows. Will this get my Idle back up, also will it tone it down a little?
Since you have a 2005 the injector issue may have ruined your cats due to running too rich.
These trucks idle real low when warm, my Gryphon as read as low a 460rpm in gear. If you want a louder idle, get a programmer that will let you adjust it. Personally i'd rather idle lower and save more fuel
That wouldn't cause a idle calm down, theres got to be a restriction somewhere, the ECM re-set would be the first thing to try.
