Does dumping do damage?
Old Mar 22, 2009 | 02:47 AM
black5.4beast's Avatar
i have heard that if you dump(turndown) your exhaust after the muffler that, after many years, the exhaust fumes can start to rot out the under-belley of your truck. Is this true? and if so, is exiting the exhaust away from the body the only way to avoid this problem?
thanks
as my first addition i was thinking of getting a Flowmaster super 44 1 in/2 out
Old Mar 22, 2009 | 03:24 AM
jerzpilot's Avatar
I can see that happening since the exhaust has water vapor in it. HHMMMM note to self, gotta exit my exhaust than and delete that down pipe today.
Old Mar 22, 2009 | 03:35 AM
lol it seems there may be some truth to that after all. i was just hoping i wouldnt have to run it all the way to the back and pay for tips and all...
Old Mar 22, 2009 | 07:19 AM
shaunakadub's Avatar
I honestly think this is something more along of the lines of people saying that side-exit exhaust make your back tires dirty...
basically a load of crap.
Old Mar 22, 2009 | 10:11 AM
bigdog87's Avatar
I bet it's a load of crap.
Old Mar 22, 2009 | 10:21 AM
It can if that area of the underbody is un-protected ( paint, factory lining, heatshield.. ) mostly because of the removal or upgrade of cats.
Old Mar 22, 2009 | 11:33 AM
jerzpilot's Avatar
Eventually unapainted or unprotected areas under the body will get rust, is best to exit the exhaust all the way out.
Old Mar 22, 2009 | 12:49 PM
jlstang351's Avatar
It want hurt anything. Thats retarded! or just dump it after the axle to avoid paying for tips!
Old Mar 22, 2009 | 01:32 PM
FX4life's Avatar
the exhaust on my truck has been dumped with turn downs, then just straight through with tips, and now dumped over the rear axle. I have been running some form of dumped exhaust for the past 4 years on my truck with zero problems from the exhaust being dumped. The only issue i can see is getting tired of the cab noise after a while, which is why mine are now over the rear axle instead of in front of the axle.
Old Mar 22, 2009 | 02:14 PM
dkgreyf150's Avatar
x2 i have had mine dumped for 3 years and no problems but it can get annoying
Old Mar 22, 2009 | 02:24 PM
tcope's Avatar
I'd imagine that any movement of the truck or any slight breeze is going to carry away those fumes anyway. Also, I can't see water vapor doing much as 1) the metal parts should all be coated and 2) water from the road is going to always be present. So if this water does not cause a problem, I can't see where vapor would.
Granted, exhaust should be routed in such a way so it does not accumulate under the truck. I'd say exhaust router near the back of the truck would probably be safe but there is just something about carbon monoxide and breathing that don't mix.
Old Mar 22, 2009 | 03:04 PM
2004Triton5.4's Avatar
My dad's truck had a dumped 50 series flowmaster installed when he bought his truck. My last truck had a dumped 40 series flowmaster and my current truck has dual dumped 40 series flowmaster's. Neither truck has experienced any type of under bed rotting. I get underneath my truck alot to check for rust or any other visible problem's and i've never noticed any carbon under the bed's from the exhaust or noticed any type of moisture that has came from the exhaust. So i'll say that claim is false. If your worried about the potential for that problem happening then just get under their with a water hose and wash the undercarriage every once in a while.
Old Mar 22, 2009 | 04:33 PM
ok thanks yall. i was just hopin to get some answers before i did anything and yall provided them.
