Using Pre-cats over Hi-flows.....
I have seen and heard from people with stangs that they have no gain from the high flows, even seen dyno sheets. There is not a performance gain from the high flows that would make them a good investment.
Tomorrow of sometime this weekend my rear cats should be coming out, hoping so. I'm almost certain I will not have a CEL problem. But cutting so close to the rear sensors is what scares me. May unplug them but then I dont know if i'm opening the oppertunity for a CEL.
If the truck isn't run without the O2's unplugged you won't have a problem. Just cut carefully. It took my truck over 500 miles to set the CEL, and it doesn't do it as often I would expect, it is wierd, but I have 153,xxx on stock O2's.
Sweet deal then. Ok thats a little more comfort. Now hopefully we can do the job right tomorrow. Sure hope so!
Yep, we're all ready, just need that sawzall from my buddy's friend, and I may need to buy a blade but thats no problem, free evening. Just gotta take measurements to make my 18" pipes 12" with the flanges able to fit over the existing piping a bit.
let us know how it turns out. hopefully i'll get around to doing this after i finish a few projects i still have going on my truck.. joshmac, did you do your own welding? i like the clamp idea, but it doesn't look like theres quite enough room for one to fit. my dad used to be a welder, but idk how much of a PIA it would be to pull the pipe down so he could weld around the whole thing.
Well guys me and my friend have cut into my trucks cats now. We need to buy better blades for the saw, god this stock pipe is stronger than we thought. So right now I have two big exhaust leaks ( we got cuts infront of the cats, cats are still in )
Will update tomorrow when we expect to have it all done.
i bet it sounds awsome! good luck man, i know its probably not to fun cutting with a saw zaw in tight quarters. especially under your truck!
Gotta wait a little for pics and videos, I dont have a fresh tape for my camcorder but im gonna find something stupid & record over it for a couple minutes.
I do got pics of the install and information....... but that waits until I get the video
My buddy and i finally got er done. i'll get some videos soon. Its sounding pretty damn sweet.
