why so many Cats
Old Jun 28, 2008 | 11:50 PM
foreman400x's Avatar
why so many Cats
What is the purpose of having 4 cats on my truck..on my 92 it only had 1..wtf..Could i remove 2 of the cats and replace the ones left with highflow magnaflow cats..if so what would be the easiest way of doing this..please post pics
Blake
Old Jun 28, 2008 | 11:54 PM
x_sgs_x's Avatar
First 2 are precats and yes you can swap them out
Old Jun 28, 2008 | 11:55 PM
Raptor05121's Avatar
With the Maggies I heard you take off both from each side and replace with one.
600Polaris's Avatar
take all four out, and replace with two magnaflow high flows, a local muffler shop can do it up. just cut out after the first o2 sensor, b4 the second. there will be some minor pipe bending that they can do easy enough. weld it up and your good. when they did mine i had them replace the o2s as well.
with high flows, no CEL, much better sounding, better flow.
Old Jun 29, 2008 | 12:40 AM
4 cats for sound resonation, and the filtering job of cats. 2 Magnaflow Hi-Flows will fix it.
Old Jun 29, 2008 | 01:17 AM
Paralyzer's Avatar
older vehicles only have oxidation cats whitch help remove HC and CO. once OBD2 came in more strict emissions came into play to reduce NOX which is where the second cat called a reduction cat comes in. they both do totally different things, removing the rear cats will make you fail emissions unless you remove both and put in a dual bed cat such as the 05+ f150 has which is basically both cats combined.
Old Jun 29, 2008 | 11:33 AM
i called my local muffler shop and they said its against the law to remove any of the cats,i may run by another shop monday and see if they will do it
Old Jun 29, 2008 | 12:36 PM
Ranger7489's Avatar
Yes, it is illegal. An if the EPA finds out the muffler shop is removing cats, they will be fined something like $10,000-$15,000.
Just lie to them, say the 2 cats you want removed and replaced with Magnaflow high flows need to be replaced because they stopped working. Trust me, they wont take the time to make sure your story is true. Just dont try to bribe them to flat out remove 2 of them. They will probably refuse to do any work to your truck because they would think you were from the EPA trying to get them to do something illegal.
Old Jun 29, 2008 | 01:16 PM
Raatikainen22's Avatar
i wanna swap stock cats for 2 hi-flows too..
Old Jun 29, 2008 | 01:35 PM
Since my truck is sneaking up on 70,000 miles and 75,000 is where cat replacement begins, my ehaust guy agreed to put hi-flows in my truck, but the catch is, it needs to be the 4 cat hi-flow system...
