Daytime Running Lights
Old Nov 14, 2002 | 07:11 PM
bikenut's Avatar
Question Daytime Running Lights
Hi Folks,
Im trying to install the Daytime Running Lights on my 2002 F-150.
I installed the relay block in the correct location in the top of the dash under the access panel, but I cannot find the plug for the resistor which is supposed to be located in the wire harness behind the left headlight...
Anyone know where to plug in the DRL Resistor on the 2002?
Thanks in advance for any guidance!
Old Nov 15, 2002 | 02:24 PM
FedExPilot's Avatar
Bike;
Have you tried this link ....... ?
http://www.geocities.com/skyjet1/DRL.html
He has a couple of pictures which helped me on my 2001 ... suspect the 2002 should be the same. Best of luck.
Old Nov 16, 2002 | 10:56 AM
bikenut's Avatar
Yep, I sure did, thanks.
I have spent ALOT of time looking for this dumb plug and even went to the local ford shop looking at the computer... All we found on the computer at Ford was the location where it is mounted on the lightning, which is on the same bracket that holds the water pump and radiator for the intercooler.
This is driving me nuts! I know it must be there because the relay harness was there
Old Nov 19, 2002 | 10:56 PM
bikenut's Avatar
Someone Pleeez help me!!
Im going crazy!!
I have removed the radiator overfill jug and that plastic cover on top of the radiator and traced the entire harness that is supposed to have the plug for the DRL Resistor. -It is simply not there on my 2002 F150.
ANYONE with a 02 who can tell me where to put this darn resistor would be my hero and save me what hair I have left!!
Old Nov 20, 2002 | 08:05 AM
wfstewart's Avatar
Should be located between the drivers (left) headlamp and the radiator. Real close to the headlight housing. It will be in the same harness as the turning signal and headlamp circuits.
Old Nov 20, 2002 | 09:49 AM
bikenut's Avatar
yep, thats where I thought it was, but I traced that entire harness
Old Nov 20, 2002 | 03:37 PM
bvhall's Avatar
I spent hours looking for that on my 2002 as well. Traced the entire harness and never found it.
Looked at my friends 2001 and it was right where they say! Guess its different now.
Old Nov 20, 2002 | 06:14 PM
bikenut's Avatar
Thanks BV, at least I know Im not a blind fool
Hopefully someone who knows where it is on a 02 can tell us...
Old Nov 21, 2002 | 10:11 AM
bvhall's Avatar
The plug with the 'jumper' under the dash cover is there for the DRL module, but no place for the resistor that I can find under the truck.
I added autolamps with no problem and was going to do DRL too.
So either we both need new glasses or somethings changed we don't know about.
Old Nov 21, 2002 | 03:37 PM
bikenut's Avatar
Ahh, Autolamps eh? Can you give me the details? I would like to do that too
Old Nov 21, 2002 | 05:54 PM
user 3282082's Avatar
My 2003 has it exactly where the website that FedExPilot supplied said it was. Can't imagine that the 2002 is different from the 2001 and 2003.
It's easier to see from underneath.
Old Nov 27, 2002 | 04:03 PM
bikenut's Avatar
hey bvhall
can you give me the details on installing autolamps on my truck?
Old Nov 27, 2002 | 06:00 PM
bikenut's Avatar
FoR SALE
OK, nevermind the info. On autolamps, I did a search and ordered the parts.
Now I have the two parts that you use for DRL if anyone wants to buy them from me, they are brand new, make an offer!
Old Nov 28, 2002 | 01:47 PM
bikenut's Avatar
The DRL Parts are sold
Old Nov 29, 2002 | 12:34 AM
pw1981's Avatar
Just an off the wall idea... on the 02, did you try just installing the relay block? Maybe they already put the resistor in somewhere????
I have no idea and havn't looked at my truck for this yet.
