Daytime Running Lights
Originally posted by welfare wagon
.....MY ?? is who did you guys go through to order the kit that uses the relay and resistor under the dash panel and behind the drivers front wheel, What prices did you pay. The parts person i spoke with where I odered this product said there is no other kit available that Ford sells. which I know is not to be true
All of the 'kits' sold by FoMoCo are universal and designed so that they can shelf one kit for all vehicles. In MANY of the vehicles the wiring for the original option is already there and the kit is more expensive and bothersome than necessary.
Check for the plugs for the resistor and relay then order the parts from the link: http://www.geocities.com/skyjet1/DRL.html ALL THE NECESSARY INFO is on that page for Daytime Running Lamps and I already set you up with the info for the Autolamps.
-Phil
