Door Adjar
Old Apr 6, 2001 | 11:46 AM
jwrape's Avatar
Angry Door Adjar
Why is my door adjar light stay on? It doesn't do it all the time just usually in the morning and also after I have been driving for a while. It keeps the Dome light on until the auto turn off mechinism turnes it off.
Has anyone else had this trouble. What did you do to fix it?
Old Apr 6, 2001 | 05:03 PM
Dennis's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by trapper:
Sometimes it works, sometimes it doesn't. I
had the same problem and tried the wd-40 with
some success. The problem came back after a
week or two. I have since tried the wd-40
and it has fixed the problem for now. There
are MANY other older posts dealing with this
problem. Good luck!
</font>
The key to the WD-40 repair trick is to use a sufficient amount of it to wash out the dirt from the switch. You probably want to leave the door open and line the baseboard with oil proof sheeting because the WD-40 will surely drip out the bottom of the door for a short while.
Old Apr 7, 2001 | 12:24 AM
Hawkeye's Avatar
Post
Sounds like the switch in the door is sticking. It's mounted inside the door on/near the latch. Some folks have reported success fixing this problem by flooding the door latch area with WD-40 and then cycling the switch by opening and closing the door a dozen or so times.
Hope this helps. I haven't tried myself, my door switches are still working.
Old Apr 7, 2001 | 12:46 AM
trapper's Avatar
Cool
problem. Good luck!
Old Apr 29, 2001 | 09:56 PM
weadjust's Avatar
Wink
I went to radio shack and bought TV Tuner Control Cleaner & Lubricant. Cost 7.99. Saturate the latch on the door, then open and close the door a bunch of times. Can says safe on plastic. If its safe to spray inside a TV it shouldn't damage your truck. Oh yeah the can also says to unplug the truck from 110 volt outlet before spraying and to check owner's manual before using on expensive equipment.
Old May 7, 2001 | 05:28 PM
phildacf150's Avatar
Wink
I just replace the door ajar switch in my driver side door this weekend. The part cost about 10 bucks. It fixed the problem. What happens is that the switch sits vertically right under the latch, and is actually mounted into the latch. Dirt gets past the pin switch and runs down and builds up in the bottom of the switch and prevents the pin frog moving all the way back up when the door is shut. WD-40 is the worst thing you could spray because when it dries it turns into a sticky residue which gums up the switch and attracks dirt.
Any? phildac@hotmail.com
Old May 8, 2001 | 07:49 AM
jwrape's Avatar
Post
What did you have to do to get to the part.
Take off interior panels? What kind of tools did you use not to mess up your interior panel?
Old May 8, 2001 | 09:26 PM
Barto24's Avatar
Post
I had the same problem with my truck, the door ajar light was staying on and the dome light was on. It happened a couple of times and did not know what to do. I used WD-40 with the red extender straw to really get it in the door latch and sprayed the hell out of it. that was about 3 months ago maybe? problem has not re-occoured yet.
Brian
98 F150 XLT Supercab 4X4
4.6L V8 3.55LS
Tonno Cover, Brush Guard, Dukes of Hazzard Dixie Horn, 2 150 watt KC Daylighters, Cobra CB Radio, BF Goodrich All Terrains 265/75/16
http://hometown.aol.com/barto24/brianstruck.html
2000 Excursion Limited 4X4, Black, V-10, 3.73 LS, Tow Mirrors
Old May 9, 2001 | 10:34 AM
Post
Hi jwarpe,
After you pop the triangle and the verticle piece of trim off the top of the door panel which are held in using a couple clips (No tools Required), Pop up the power doorlock and window switch cluster held in by the sane type of clips (No tools needed but kind of tight). Undo the electrical connections to the switches. Remove the little round cover next to the handle and unscrew the bolt holding the handle on. You don't need to completly remove the bolt. Pull the handel through and set it aside. Finally remove the push pins at the top of the door panel at the front and back of the door, then lift the whole panel up about 2"and pull back toward you. Be sure to unhooke the light bulb in the door by rotating the fixture 90 degrees. Taking out the latch and door lock actuator is a whole different story. Let me know!
Old May 9, 2001 | 10:39 AM
Post
Almost forgot,
I went to the Ford Dealer and got the part. If you want the part number let me know, I have it out in my truck.
<font face="Verdana, Arial" size="2">Originally posted by jwrape:
</font>
Old May 10, 2001 | 01:53 PM
ane182rf's Avatar
Question
I've noticed that my door adjar light can stay on some times after closing the door. It is usually a random occurrence with the exception at night (cool environment garage) and can be triggered by either door. This is interesting because rarely do I open my passenger door to allow entry of dirt.
In addition, the dome light sometimes extinguishes 2 minutes before the door adjar light goes out. I am starting to think the GEM (generic electronic module), which controls these functions in addition to others, is a little wacked out. Perhaps one or two of the internal circuits is partially defective due to manufacturing quality, causing improper operation, who knows...
I've seen many of these modules go bad on other Ford product lines such as early to mid 90's taurus, town cars, crown vics, etc... A common sympton was that windshield wipers would stick midway thru their cycle.
Bob
