Where to get DRL parts for '06 S-Crew?
OK, I have looked at the Tech Article:
http://prweb0.voicenet.com/~storm/drl/
I am now trying to find the parts.
My local dealer is no help at all. Gave them the part numbers and they still won't order it and give me a credit if the parts they order are wrong. Weird!
Here are the parts...
Relay Block - Ford Part Number YL1Z-13B218-AA
Resistor - Ford Part Number XL3Z-14A601-AA
Sheesh, finding a part for the space shuttle couldn't be this hard!
Thanks,
-Mark-
Thanks,
-Mark-
Any f the online places can look up by PN.
Dealers in no particular order :
www.fastpartsnetwork.com
Fast Parts Network, LLC
652 Nautical Way
St. Augustine, FL 32080
Sales:
sales@fastpartsnetwork.com
www.southwestfordparts.com
Southwest Ford
3000 Fort Worth Highway
Weatherford, TX 76087
V: 817-596-8074
Keith Sexton Asst. Parts Manager
www.fordpartsonline.com
Bob Utter Ford
2525 Texama Parkway
Sherman, TX 75090
v:866-941-FORD
www.tascafordparts.com
Tasca Automotive Group
1300 Pontiac Ave
Cranston, RI 02920
v: 800-915-3141
www.thinkpartsguy.com
F150online.com Site Sponsor
1100 Oyster Bay Ave South
Bremerton, WA 98312
www.directfordparts.com
Silver State Ford
2121 E SAHARA AVE
LAs Vegas, NV 89104
BTW XL3Z14A601AA was superseded by 1L3Z14A601AB
There will be the normal mechanical and collision catalog area, just below this is the Search by Factory Part Number area.
652 Nautical Way
Sales:
Southwest Ford
V: 817-596-8074
Bob Utter Ford
2525 Texama Parkway
Sherman, TX 75090
v:866-941-FORD
1300 Pontiac Ave
Cranston, RI 02920
v: 800-915-3141
Bremerton, WA 98312
Silver State Ford
2121 E SAHARA AVE
LAs Vegas, NV 89104
Mark, I don't think you can quite do this mod on your truck the way the article shows. If you look at the plug behind the headlight, I think you'll find it is not wired for DRLs (unless your truck came from Canada, and then you'd have DRLs already).
But, all is not lost. I think you need part number F6SZ13B218AA and you can order it here (as I did): http://www.trademotion.com/partlocat...&siteid=214072
But - there MAY be one catch. The ones shown there don't seem to be right for 2006 trucks WITH autolights, which I assume yours has. Mine has autolights and the module worked fine. I'd call them and verify it's the right part before you order.
Installation involves cutting into a few wires behind the dash, but it's a pretty easy afternoon job. The result is a TRUE DRL system - lights operate at 60% brightness during the day, they go off if you set the parking brake and come on full bright automatically at night.
- Jack
- Jack
Thanks guys, you're awesome.
Looks like I have more to go on now.
Trademotion has a kit:
Description Qty MSRP Price Your Price Core Price Total Cost
Collision Catalog - 2006 - Ford - F-150
Electrical, Daytime running lamp components, Accessory kit, W/autolamps, W/autolamps $69.46
No P/N? Hmmm...
I will give them a call tomorrow and see what this kit is.
I'll keep you posted.
-Mark-
No P/N? Hmmm...
-Mark-
...<snip>....
No P/N? Hmmm...
-Mark-
No P/N? Hmmm...
-Mark-
Just something to make sure of, but the DRLs are mostly hidden, so the add on parts might not have that much of an impact.
Make sure this is using as much of the factory wiring as it can. I know the autolamps add on kit uses a stick on sensor on the dash, instead of using the factory location sensor.
Mark, the price you're getting from Trademotion is pretty much the MSRP for the unit. Millennium Ford sells it for $59, but verify it's the one you want (I'm sure you must have autolamps).
- Jack
I know the 99-03 add on for the autolamps ( not the same item ) was a spit, toilet paper & duct tape add on item. Kind of worked poor, and looked like crap.
The DRL resistor is in the 2"x2" box ? With it on the parking brake bracket, should not be an issue, but does that thing get hot in there ?
That is why they mounted the DRL resistor next to headlamp housing, out in the air flow on the factory setup.
Good to know jack, thanks for the info.
The result was pretty tidy. I taped the wires from it to existing wire bundles using that new, non-sticky "stretch" tape and wire ties so nothing hangs down or looks bad. Here's a picture:
As you can see, it has it's own fuse. Upon looking at the box though, I think the dimensions are about 1.5 x 2.5 x 1.
- Jack
