another power window problem
Old Jan 25, 2008 | 02:38 PM
j2h1's Avatar
Well, today I washed the bird waste off my truck and let it sit inside for a while as I hand dried it (it's 32* out). When I went for a drive my windows wouldn't go down. It doesn't seem that they are frozen 'cause they don't even try to move. I also noticed while the truck is running and the door open when I push any window button I get the beep when you open the door when running and the door ajar unlights like there is a short?. None of the buttons on any door work. Any suggestions or heard of this before? I have no warranty so all the work I do myself if possible. My rear slider works but that switch is up by the dome. Is there a fuse? I did see the breaker, pulled it and put back in. 2005 supercab.
Old Jan 25, 2008 | 02:41 PM
i would check fuse first i can look it up a little later if no one else has responded
Old Jan 25, 2008 | 03:21 PM
j2h1's Avatar
n e 1 know the fuse #? I can't find it in my manual or a haynes book. I see a circuit breaker #401. How can I check if that is working?
Old Jan 25, 2008 | 05:24 PM
windows F401 30amps Circuit breaker
door locks are on F22 10amp
thats all i could find in the fuse block listings. If you want i can email you the diagrams for the window circuits, and fuse listings. send me an email if you are intersested.
Old Jan 26, 2008 | 01:54 AM
j2h1's Avatar
Thanks Patman. I've got the fuse listings and such in my manual. Could it be the circuit breaker? How can I tell if the breaker is working? The door locks and mirrors work. I guess I could take apart the door later and make sure the plug didn't come off.
Old Jan 26, 2008 | 10:00 AM
masseyman's Avatar
Don't rule out the fact that the windows may be froze shut . On my '88 F-150 the driver side window will freeze shut and it acts like everything is dead. Except if I watch the battery guage when I hit the switch it goes to the left.
Old Jan 26, 2008 | 11:33 AM
j2h1's Avatar
I just checked the situation again. The battery needle does not move with any window button even all four at once. I took the button panel off and everything is plugged in, I unplugged the windows and back in. Nothing. I am going to advance to get a circuit breaker hopefully. I just hope this isn't a wire issue.
Old Jan 26, 2008 | 12:45 PM
j2h1's Avatar
Now, none of my auto places have a 30A breaker. I went to the dealership and he had me try a 20A fuse before ordering a breaker for $10. The fuse does not work either. I guess it's time to trace wires.
Old Jan 26, 2008 | 10:31 PM
j2h1's Avatar
disregard fuse and/or breaker
new development, I was driving tonight and noticed the switches light up. I got power. When I push a window switch my switch lights go out and the heated mirror light comes on. When I turn on the mirrors (switch under radio) the switches go out. Sounds like a short somewhere in the door. I will update when I make progress.
Old Jan 27, 2008 | 12:57 AM
Ford4x4er's Avatar
ya pat man got the same fuse ## i did
Old Jan 28, 2008 | 10:46 AM
j2h1's Avatar
Talking Wooohooo! Found It!!!!
Here was the problem. I was about to take door panel off but decided to check inside. When I closed the door they worked. Opened it and no power. Pulled the rubber piece back and there it was! Used a 10-12 AWG butt connector to fix it.
There is not play in those wires. Thanks for the help.
Old Jan 28, 2008 | 12:57 PM
glad you found your fix. Typically if it is an intermitent problem it is not a fuse/breaker problem.
for a safe long term fix you need to solder a wire in there and put some rubber heat shrink on it....
