Remote starter when cold
Old Jan 3, 2008 | 01:49 AM
memLT-1's Avatar
06 F-150 with ford remote start. The remote stare will not start the truck when the temp gets below 20 deg. It will just click and then quit and try again for a few more times. It will however start with the key like regular. The dealer says to bring it back and leave it over night when it gets below 20 deg. well it doesen't get that cold here that often but when it does I expect the darn thing to work.
Old Jan 3, 2008 | 01:51 AM
azmidget91's Avatar
does it crank at all?
Old Jan 3, 2008 | 02:27 AM
RightTurn's Avatar
good thing i didnt get one.
it was 6 degrees last night coming home from work.
Old Jan 3, 2008 | 02:31 AM
memLT-1's Avatar
With the remote no it does not crank. The starter will click a few time then stop.After a few seconds
'30 maybe it will retry, after about 4 times it will stop. But at any time I can unlock the door and start it with the key like normal.
Old Jan 5, 2008 | 10:17 AM
daculatruck50's Avatar
Your truck want start because the remote starter is in "tachless" mode. This is a easier way to wire up the remote starter. Ford will have to wire the system up in "Tach" mode. It is just to cold for the system to perform correctly without a direct connection to your engine. I'm here in GA and i dont need to wire to the engine but up north "tach" mode is very important for correct operation.
Old Jan 5, 2008 | 01:08 PM
roushstage2's Avatar
That is some useful information right there.
Old Jan 5, 2008 | 06:09 PM
Extreme Justice's Avatar
This is exactly what happens to mine to the T. (same model year and everything) Here in Canada it gets to 20 deg regularily. If you find the answer please let me know! I just read dracs post. I'm up for my 15,000 km maintenance so I will bring that up to my service dept.
Old Jan 5, 2008 | 07:46 PM
LastSplash's Avatar
Do the lights flash when you try to remote start the engine? If they do I would check the hood pin switch. I have a remote starter (not factory) and it works fine all the way down to a least -60F and it is in tachless mode, the only problem I ever had is that the hood pin switch grounded out one time.
Old Jan 5, 2008 | 08:12 PM
Veteran: Army
try a higher Cold Cranking Amp (CCA) battery, a guy at work had a similar issue and a higher CCA battery cured the problem for him
Old Jan 6, 2008 | 06:48 PM
I can go outside and using the key the truck starts fine, with no hesitation. So I don't think it's a weak battery issue.
Old Jan 6, 2008 | 06:56 PM
gators241987's Avatar
I take it based off your screen name your from memphis, which dealer did you take it to? did they install it there or was it elsewhere?
Old Jan 8, 2008 | 03:33 AM
memLT-1's Avatar
Landers in Collierville. I'm going to check into this tach or tachless mode thing.
Old Jan 8, 2008 | 07:24 AM
memLT-1,
If you find out anything let me know and I'll do the same.
