97 F150 No brake lights, turn signals, cruise
Old Jan 8, 2008 | 04:00 PM
luv4fords's Avatar
I have a 97 F150. The brake lights, turn signals, and cruise control all won't work. All of these problems and the ABS light showing up occasionally. I have checked the fuses and all are good and there is power on both sides. I have not checked any relays yet, and was curious if there was a shared relay or a fusible link which would knock out all of these at the same time. It does have tailights and back-up's working. Thought it would be better to ask in case someone has had this same problem happen.
