Fog Lights
Old Mar 15, 2007 | 04:57 PM
1st 150's Avatar
Fog Lights
I was wondering if someone could help me out with fog light installation on a 98 sc? It doesn't come with factory fogs but the head light switch does pull out. I have some knowledge with electrical but I could use some advice on how to hook them up.
Old Mar 15, 2007 | 10:15 PM
off road dude's Avatar
im trying to figure this out too on my truck a 97xlt now if your truck is 4x4 like mine the wiring harness should be there if it is 2wd you need to do a lot of mods to get them. look way up under your front bumper the plugs should be on the frame. the fuse should be in the fuse box. my switch pulls out but when i test the plugs there is no power. if your switch says pull for fog lights you should be good but if it doest then you need one that says that because i think that is the final connection in the circuit. go after market on ebay for the lights
Old Mar 15, 2007 | 10:41 PM
JTDEERE's Avatar
My truck is a 4x4 with the black covers in place of fog lights and I cant find a harness or anything anywhere.
Old Mar 15, 2007 | 10:48 PM
its not quit behind the bumper it more or less in front of the wheel well up on the frame and ford might not have put it on all trucks
Old Mar 16, 2007 | 09:49 AM
JTDEERE's Avatar
Hmm ok, I'll look anyway. Thanks.
Old Mar 16, 2007 | 08:10 PM
1st 150's Avatar
My switch doesn't say "pull for fog lights", but it looks like I do have two empty harnesses there. So I would need to get the fog light switch and I'd be in business? No other wiring to do? Just adapt the fog light wires to the factory plug?
Old Mar 17, 2007 | 01:15 AM
that should be it but im not 100% sure take it to ford and c if they say it would work and after that tell me cuz that is what i am hung up on
Old Mar 18, 2007 | 10:39 AM
JTDEERE's Avatar
I'd like to know if it will work too.
Old May 4, 2007 | 11:05 PM
iwashmycar's Avatar
Bringin this back. Anyone get it to work?...or find the plugs?
I just got a "lightning style" cover with fogs for my 97 and it has the pull-out switch. I am going to look further up behind the wheel well tomorrow, but I thought i'd check with everyone! If its not there is there an easy way to wire them in with the stock switch?
Old May 5, 2007 | 04:22 AM
LastSplash's Avatar
A quick easy way to power fog lights is to use the 12v supply to the parking lights to energize a relay that turns on the fog lights.
Old May 5, 2007 | 09:25 AM
svt2205's Avatar
Back when I had my 98 I wanted to do the same thing. I ended up buying the, then available, fog light kit from Ford. That gives you all the necessary parts to wire in the lights. It did include a new switch because the non-fog light switch is not set up for the extra lights.
I'm sure you could go the old fashion way, for a lot less money and agrivation with a toggle switch, relay, wiring and the lamps.
Old May 5, 2007 | 10:39 AM
iwashmycar's Avatar
Ya that is what I kinda wanted to do if i have to. On my 1990 Mustang GT there is a write-up I used to do the parking lights + fogs mod, using a simple relay.
Is there a write-up anywhere with wire colors and whatnot?
Old May 8, 2007 | 04:31 PM
PROxac's Avatar
Does this apply on later years? (2003)
