Problems removing Tailights quick help...
Old Jan 14, 2007 | 12:58 PM
SuperLB51's Avatar
I am trying to remove my 2 rear tailights off of my flareside...I took out one screw on the inside of the bed...is that all there is? I have pulled and yanked to the point I almost broke one of the lights and they wont come out....HELP!
Old Jan 14, 2007 | 12:59 PM
built54's Avatar
pull, they will come.
Old Jan 14, 2007 | 01:02 PM
SuperLB51's Avatar
reason for pulling...tryin gto move the bed back about 18 inches or so so I can reach the fuel pumps...I cant drop the tank...its full...Is there an easier way to unplug the harness from the light? when i got under there I saw a little hole where the wire goes in but I cant get my hand up there to pull the connector off...
Old Jan 14, 2007 | 01:09 PM
built54's Avatar
just pull the light towards the outside of the truck, they will pop out
Old Jan 14, 2007 | 01:26 PM
SuperLB51's Avatar
i have pulled and pried and yanked and pushed and hammered and they wont come out...I am a big guy and i think I cracked one of the lenses...
Old Jan 14, 2007 | 01:42 PM
built54's Avatar
hmm...i dont know then, but i know mine were tight, wait you said 1 screw, there is one on top and one on bottom.
Old Jan 14, 2007 | 01:53 PM
SSCULLY's Avatar
Dumb question, did you read the procedure on page 204 in your owners manual ?
If you don't have an owners manual, you can download one here :
https://www.fleet.ford.com/maintenan...ls/default.asp
or here :
http://www.genuineservice.com
or here :
http://www.motorcraftservice.com
It shows the bolt locations, and the direction to toe the lense out ( as described above ) to remove the lense.
Old Jan 14, 2007 | 02:06 PM
Yah you should be pulling towards the rear of the truck. Also might snake a finger into the back side somewhere, and try and push and pull at same time.
Old Jan 14, 2007 | 02:26 PM
SuperLB51's Avatar
that was it...the toher bolt was hiding behind the tailgate srap...
