programming keys when you have 2 of them help??
Old Mar 20, 2006 | 06:32 PM
miloford's Avatar
i have 2 keys i got with a 2000 ford f150 i just bought. they are not ford keys but they work fine. i bought some kees off ebay and when i do the on off thing with the 2 good keys and then put in the new one to be programed the theft light just blinks. why dont it work??? anyone have a clue. i had one dealer try it and he had no clue either. i bought 5 keys off ebay and tried all of them and none work. any help would be great. thank you
Old Mar 20, 2006 | 06:58 PM
lees99f150's Avatar
if you are doing it correct then you may have been ripped off. are you sure the keys are PATS and have the chips inside.
Old Mar 20, 2006 | 07:02 PM
miloford's Avatar
hi good question. i know they have the chip in them cause i poped the top off to check and they do. go look at item 8045182742 on ebay these are the keys i bought. it does not say pats it says transponder keys are there different keys and are these the wrong keys for my truck. let me know also my 2 working keys are H72-PT and that is the ones i am trying to program. thanks for helping me
Old Mar 20, 2006 | 07:23 PM
SSCULLY's Avatar
I know when I did my first extra key for my '06 I was hauling @ss through the on - off, and the first time I got the same results, falshing theift light.
Try it again, at a rhythmic pace, for all 3 keys and it should work. That is what I had to do. I think I did the on - off too fast the first time.
If you have the transponder keys, you should be good to go.
Old Mar 20, 2006 | 07:30 PM
miloford's Avatar
i tried it like 8 times and a dealer tried it once and none work. i dont see how 5 keys could be bad but i think i am gonna go to a dealer who sells the keys cut for 19.00 and they program them for free and see if he can do it with his own new key. other than that i have no clue
Old Mar 20, 2006 | 07:53 PM
davidshick2's Avatar
I got mine off ebay from http://www.amazingkeys.com/ cheaper on ebay than his store...got 2 for 25 dollars with program instruction worked great excellent product............. ebay site is http://stores.ebay.com/AMAZING-KEYS
hope this helps
Old Mar 21, 2006 | 03:25 AM
Kool Aid's Avatar
I'm pretty sure you need the original keys to program another key.
A new key from 2 originals is the way I did it, but I don't know about a new key made from copies.
Does any one know for sure if you can make a new key from two copies?
Old Mar 21, 2006 | 08:59 AM
SSCULLY's Avatar
Originally Posted by miloford
i have 2 keys i got with a 2000 ford f150 i just bought. they are not ford keys but they work fine. ..<snip>...
I just realized something. You are the 2nd or maybe the 3rd owner of the truck ?
Since the 2 keys you have are not Ford keys, you might be at the 8 key limit for programming ? You know there are at least 4, the 2 factory keys, and the 2 non factory keys you are currently using.
Don't forget if you have a remote starter, this is one of the 8 keys with the PATS interface.
