Edge Evo...
Old Nov 30, 2010 | 10:50 PM
navybrat02's Avatar
Edge Evo...
I have the Edge Evo and am wanting to know what settings y'all are putting everything on in the extreme setting... all i do is up the speed limiter to 200 and correct my tire size...
Old Nov 30, 2010 | 11:18 PM
Before I got custom tunes on my Gryphon which is the same as the evolution, kinda sorta, I ran the canned level 3 performance tune without changing a thing and liked it just the way it was......
Old Nov 30, 2010 | 11:42 PM
WILDMAN442's Avatar
I thought the Evo's didnt have extreme on the gas models?
Justin
Old Nov 30, 2010 | 11:44 PM
navybrat02's Avatar
they have the transmission, towing, and extreme stages
Old Dec 1, 2010 | 07:15 AM
MGDfan's Avatar
Hi & Welcome!
Here you go - https://www.f150online.com/forums/4381866-post9.html
No Search needed!
MGD
Old Dec 1, 2010 | 09:56 PM
navybrat02's Avatar
Thank you! I'm going to try it out!
Old Dec 18, 2010 | 02:08 PM
navybrat02's Avatar
so i've messed around with it a little with the suggestions y'all have given and took it out for a test run...
93 oct on Level 3 Extreme, drop-in K&N filter w/ AIRAID Intake Tube, Flowmaster 40-series single in/ dual out turned down.
Changed Settings:
WOT Fuel: +1.5
WOT Shifts: 1-2 5250 2-3 5250 3-4 4800
Max RPM: 5650
Max Speed: 200 lol
WOT Shifts: 1-2 +12, 2-3 +12, 3-4 +9
1/4 mile- 15.16 @ 91.1mph
1/8 mile- 9.80 @ 74.6mph
0-60 @ 7.38
Anything y'all can think of I can do to improve my times besides a driver mod?? Going to the drag strip tomorrow to see what it does...
Old Dec 18, 2010 | 02:18 PM
Pretty impressive 1/4 mile stat's for a heavy truck. Shorter diameter rear tires may help you pull harder off the line and opening up the exhaust with cutout's or header's.
Old Dec 18, 2010 | 05:47 PM
Veteran: Army
Changed Settings:
WOT Fuel: +1.5
Max RPM: 5650
Max Speed: 200 lol
0-60 @ 7.38
custom tune, better spark tables, forced induction, head work, cams, higher compression pistons to name a few
Old Dec 18, 2010 | 08:16 PM
navybrat02's Avatar
as far as tires go all i have are my A/T 275/60R18...
Old Dec 19, 2010 | 05:41 PM
Drewcifer1806's Avatar
that actually really helped me out too, thanks!!
Old Dec 20, 2010 | 12:19 AM
navybrat02's Avatar
ok the track trip was ok... the track was crap and they wouldn't let me line up in the groove... here are my times...
Old Dec 20, 2010 | 12:30 AM
navybrat02's Avatar
is there a difference in the programmers simulation 1/4 mile / 1/8 mile to a real drag strip??
Old Dec 20, 2010 | 11:10 AM
JackandJanet's Avatar
Probably some. The programmer can't tell if your tires are slipping, so it might record more distance than you actually travel. And, if your TS and GR aren't perfect, you're going to get bigger errors.
- Jack
Old Dec 20, 2010 | 07:06 PM
navybrat02's Avatar
ts gr??
