Edge Evo...
here's my pass against a guy who can't keep his mouth shut...
http://www.youtube.com/watch?v=MpsTPsvnoU4
ok with the programmer isn't it suppose to be able to tell what all came stock on the vehicle when you plug it in?? when i redid mine last night it said i had 3.72?? now that i changed it to 3.55 my speedo is now higher then my gps shows... the tire size is correct as per what is shown in the booklet (even did the math)... back to the drawing board to try to get my speedo close to where it's suppose to be...
^ The VID block in the PCM.
https://www.f150online.com/forums/3845794-post9.html
https://www.f150online.com/forums/3846009-post12.html
For OEM values - that's how it's supposed to know - but sometimes it simply doesn't work -so it's always wise to enter/confirm both TS & GR yerself ...
MGD
MGD
But, your Tire Size (TS) is too large. You are not accounting for "squish". I'd reduce it to about 2524. If you enter 2602, it should make your truck's speedo read much higher than it should. When you get everything right, you should probably see 72 on your dashboard speedo if your GPS is showing 70. This will make your odometer correct.
- Jack
