ATTENTION: New Gryphon CS/CTS owners
Old May 12, 2010 | 01:57 PM
Just want to add to this sticky.
If you currently have a CS/CTS and have custom tunes loaded on them, please just hold off on Edge's updates until Bill from PHP looks into an issue that may happen.
Jack or I will post back when its fixed.
Thanx
Old Jun 1, 2010 | 02:48 AM
06fx4shadow's Avatar
WOW this thread was extremely helpful. I had no idea how the custom tunes worked. It took me a little while to realize the cs/cts was an EDGE tuner and not the Gryphon tuner. This info is helpful because I am interested in getting a tuner but wasn't sure how the custom tunes worked. Thanks!
Which is better, the Gryphon or the EDGE CS/CTS for right out of the box and custom tunes?
Old Jun 1, 2010 | 06:20 AM
shotgunz's Avatar
The Gryphon CS/CTS is better because it can be custom tuned.
The Edge CS/CTS cannot be custom tuned unless you send it to PHP and get it upgraded to a Gryphon.
Old Jun 1, 2010 | 12:54 PM
JackandJanet's Avatar
I'm going to make a small correction here. If you have a CS/CTS, you do NOT have to send it to PHP to be "converted". PHP will make your custom tune(s) available on the Edge server, through the Fusion application. When you download them, your unit becomes a Gryphon CS/CTS.
All you really have to do to get a custom tune for the CS/CTS is provide PHP your unit's Serial Number and your truck's hex (calibration) code. And, of course, you have to pay for the tune(s). The details are on the PHP website.
- Jack
Old Jun 1, 2010 | 01:05 PM
shotgunz's Avatar
Small my butt! That was a badly needed MAJOR correction.
This whole Edge/Gryphon/Evo/CS/CTS thing has me totally confused.
Hope they don't come out with a new model anytime soon.
Old Jun 11, 2010 | 04:37 PM
I missed this one good thing Jack was able to correct you.
Old Jul 31, 2010 | 02:50 AM
slimcubby's Avatar
In case anyone is confused here:
1. BOTH the Gryphon and the CS/CTS units come with canned tunes that you can use immediately. You will undoubtedly see improved performance.
2. To create your custom tunes, Bill Cohron at PHP needs the "HEX" code from your PCM, which you will be able to read once you plug the Gryphon or CS/CTS into your truck.
3. Once your custom tune(s) are ready (you can order 1, 2, or 3 - I have 2), you will receive an email notification.
4. If you have an "old style" Gryphon (monochrome screen), you plug the Gryphon into your PC, with an application called "Pegasus" (that you download from PHP) running and it installs the tunes into your Gryphon.
5. If you have a CS/CTS, you plug the unit into your PC with an application called "Fusion" (that came on a disk with your unit) running and it installs the tunes into your CS/CTS.
Hope this clears up some of the confusion.
- Jack
Jack, I don't have a PC I have a Mac. Do they have the software available for Mac as well?
Thanks!
Paul
Old Aug 1, 2010 | 06:20 AM
MGDfan's Avatar
Thanks!
Paul
Jeez, Paul!
The answer appears to be a (conditional) "NO"...
Read the 'notes' for the Fusion and Lightning software:
http://www.edgeproducts.com/product_updates.php
And, from PHP's website FAQ section:
"Is Pegasus, Phoenix Flash, or Minotaur compatible with either a Mac or with Windows XP/Vista 64?
For a Mac, these products will only work on Intel processor Macs running OS X and using Parallels or VMware Fusion and a Windows overlay.
If running Vista 64, the software will require the download of the new USB drivers available HERE. "
Beg/borrow/steal a real pc
MGD
BTW - time to start doing this research on yer own - my typing finger is getting kinda numb
Old Sep 12, 2010 | 09:38 AM
craneop35's Avatar
My CTS should be here in a couple of days.
Old Sep 16, 2010 | 08:30 PM
xplorgee's Avatar
I am still waiting on getting Edge to add my trucks code to the server back to my CTS. I hope it doesnt take too long.
Old Sep 21, 2010 | 08:45 PM
crimson150's Avatar
wow, this was incredibly helpful...wish I would have known this earlier (my own fault). Now I'm not confused as to why I had a "canned" tuner...I need to upgrade so I can custom tune for what I want to do to my truck.
Thanks for this sticky!
Joey
Old Nov 28, 2010 | 09:57 PM
FX4INPROGRESS's Avatar
This is probably a stupid question, but what exactly is the "tranny Only" tune. Does it just adjust shifting or....
Old Nov 28, 2010 | 11:36 PM
Tranny only means just that...tranny only.
Makes it possible for the canned shifts to be loaded or adjusted and that's it plus ts+gr......which is a little bit more limited on a CS+CTS.......than a monochrome Gryphon.
None of the engine parameters are reprogrammed in the pcm....the stock af tables and timing curves are not disturbed during the programming.
Old Dec 21, 2010 | 07:45 AM
60DRB's Avatar
Well, ANYway, I should get my "plain old Gryphon" in the next couple of days...
Old Jan 3, 2011 | 04:11 PM
BigTerp's Avatar
My Gryphon CS shipped today!!!
I ordered my unit on the 25th with 3 custom tunes. PHP was out of stock due to their holiday sale, and Edge was closed all last week. I'm sure it will be worth the wait though.
