Just installed my Edge Evolution
yeah settings.
Gotcha, I have the link bookmarked on my other computer so I can get it for you tomorrow. 1.5 WOT fuel, 5650 rev limiter, 1 timing because I'm running 93. I'm at 10 for 1-2 shift, 10 for 2-3 shift and 8 for 3-4 shift. I don't remember the shift revs
With that max, the shift revs should be no more than 5250, 5250, and 4800.
Thanks!
Don't worry I already put in the settings you gave me from earlier. The only thing I haven't done yet is push my timing up because of the fuel that is in my tank right now. Once I am on "E" I will change to level 3 when I'm at the pump pouring in the good stuff.
Also, I would not run the fuel below about 1/8. You may have sediment.
I figured I would have to enter the settings again, but thanks for the tip on the fuel. If I switched back and forth from level 2-3, would I have to enter the settings again? Or would it remember them from the previous time?
I'm on level 3 with 93 octane, 1.5 timing, and other minor adjustings. Loving it very much, trucks a beast. Went from a 9.1 0 - 60 to a 7.26.
That is what I was saying in the previous post. When you change tunes, you have to reenter all settings including tires and gears.
But - If you do this and are changing from a Level 3 tune where you had the timing advanced +1 degree (because you were using 93 octane) and now you are burning 87 octane and you are retuning at Level 2, after you "Reload Previous Settings", you will need to scroll to the Timing option and set it back to zero, or it will be over advanced.
- Jack
