Just installed my Edge Evolution
Unless, you scroll immediately to "Load Previous Settings" and press [Enter]. If you do this, all the settings from your previous tune will be used in the current tune. Now you won't have to reenter everything.
But - If you do this and are changing from a Level 3 tune where you had the timing advanced +1 degree (because you were using 93 octane) and now you are burning 87 octane and you are retuning at Level 2, after you "Reload Previous Settings", you will need to scroll to the Timing option and set it back to zero, or it will be over advanced.
- Jack
- Jack
There is nothing clear about this in the manual at all, so it's a mostly misunderstood feature.
- Jack
I remember when a member here said he knew some guys at a company called Edge, and that they had asked him if he would test their new product for gas Fords. He put anyone that wanted to be a beta tester in touch with them. A few of the guys did it. Later, they started selling them and it was pretty exciting. They had lots of wrinkles to iron out, but made a go of it.
