Edge and Catback
Old May 27, 2008 | 01:28 AM
  #31
weshova's Avatar
Originally Posted by openclasspro#11
according to the edge mpg display or miles divided by gallons method?
does anyone elses edge read wrong?? my edge said i was averaging around 15.4 for a tank of gas and when i penciled it out it only made 13.67
Old May 27, 2008 | 06:18 AM
  #32
Groovy Chick's Avatar
Former Sponsor
Originally Posted by BMLocal175
The website says custom calibrations included in the price of the tuner.
I thought it was 50 bucks a tune?
Hi there,
Just to end the confusion (I hope!)... the prices of our programmers and chips include the custom calibrations. Some of our current customers make changes to their modifications and request new custom tunes (billed per tune). The Edge Evolution cannot be custom programmed due to Edge's CARB certification, but we have an upgrade offer, and customers can purchase 1, 2, or 3 custom calibrations. However, programmers are not the only things PHP sells! Sometimes, a customer doesn't need several different levels to choose from and opts to have his vehicle live-tuned by Bill and his computer reprogrammed with one calibration using a different method other than a programmer. There are other situations where customers order custom tunes, as well, but they're few and far between.
Hope this helps!
Old May 27, 2008 | 06:54 AM
  #33
openclasspro#11's Avatar
unless your math is wrong or you entered wrong digits into ure calculator-i'd say the edge is wrong
Old May 27, 2008 | 09:04 AM
  #34
I could not figure out what mine was reading so, never paid much attention to it. I keep a record of every fillup in a spreadsheet. I think "miles driven divided by gallons used" is the only accurate method of mpg.
Old May 27, 2008 | 09:22 AM
  #35
cc0517's Avatar
I would have to agree with you on the method of getting your true mpg. I just meant that according to the mpg read out on my truck it is getting 2 mpg more with the edge than it was before the edge.
Old May 27, 2008 | 09:46 AM
  #36
Ok, I misunderstood. I hope it is telling you the truth!
Old May 27, 2008 | 10:20 AM
  #37
JackandJanet's Avatar
If you programmed the PCM with the Edge and did not change the tire size (and gear ratio) from whatever the Edge uses as a default, then your PCM is going to use these (possibly erroneous) values in the things it does. The PCM "records" distance by counting wheel revolutions (on the rear wheels, according to several posters in another thread) and if it has a tire circumference value that is too large, it will display more miles driven than you actually drove on your KR dashboard display. Additionally, it would display better gas mileage there too. Dividing miles driven by gallons used won't be accurate either since the miles driven figure is wrong.
The Edge manual gives circumference values for common tire sizes and Bill Cohron at PHP recommends reducing those values by 3% to account for tire "squish". That's exactly what I did with my Gryphon and truck and I find the speed and distance displays are now correct (the truck's speedo reads about 2 mph fast at highway speeds due to some "design feature" Ford uses).
More importantly though, the PCM needs the correct tire size and gear ratio to shift at the right points and possibly do other things relating to speed.
Hope what I've said isn't too confusing. We had a rather large discussion of this in another thread in this forum a few months ago.
- Jack
Old May 27, 2008 | 10:24 AM
  #38
The mph on my Edge is right on with a GPS and as you say, the truck speedometer is 2 mph fast. This does seem to be the standard. Maybe it's a manufacturers method of eating up the warranty period a little quicker.
