Disable PCM re-flashes :)
Old Nov 8, 2007 | 03:27 PM
i.ride.suzuki's Avatar
I found a pin to pull to disable PCM re-flashes, let me test it out and see if it works well against those unwanted dealer re-flashes. I will keep you updated.
Old Nov 8, 2007 | 03:33 PM
05supercrew's Avatar
Nice, let us know. Ill be doing this right away if it works.
Old Nov 8, 2007 | 03:36 PM
MGDfan's Avatar
Crap. And I was just getting ready to install a dummy PCM under the seat hooked up to the OBD port to fool those flash-happy ****'s
Good work, Suzook!
MGD
Old Nov 8, 2007 | 04:03 PM
It would be kind-of-nice to have a hidden 'Flash ON/OFF' switch if you do change tunes.
I will keep you guys posted, the only problem i see right now is the IDS throwing a 'body' DTC.
Strategy : TEJF4
Filename : TEJF4P2
Module Part Number : 6U7ADKA
Vehicle: F-150
Engine Type: 3V
Capacity: 5.4L
Transmission: Automatic
Fuel Type: Gasoline
Emission level: 50 State Emission
Old Nov 8, 2007 | 04:33 PM
slow's Avatar
Is it a pin on the OBD2 port ?
Old Nov 8, 2007 | 06:24 PM
Oh yes. I really have no use for it but i hope it works against IDS for others.
Old Nov 8, 2007 | 09:08 PM
mgp32's Avatar
Why do people get so upset when they flash? Why don't you just flash your truck back to stock before you go in??
Old Nov 8, 2007 | 09:27 PM
F150Truck'in's Avatar
No big deal if you are running canned tunes, but with custom tunes, a reflash means you have to buy new tunes and if you don't know the dealer just reflashed you PCM and reload your custom tunes... you could corrupt your PCM and not be able to return to stock, truck will not run, tow to dealer for reprogramming...
Get the idea now, hence, upset would be a understatement...
Old Nov 8, 2007 | 09:28 PM
I'll be keeping a eye on this thread....
Old Nov 9, 2007 | 01:50 AM
mgp32's Avatar
Oh really! I was thinking about getting Troyer tunes after this winter but after hearing this IDK. I thought as long as you turn it to stock when you go in you will be fine becasue dont they just flash the same code you have in the truck already??
Old Nov 9, 2007 | 02:11 AM
Lumadar's Avatar
The base code on which they tweak and build the custom tunes are required for it to work. If you change the base tune with a re-flash, then you lose the ability to re-install the aftermarket tunes.
Old Nov 9, 2007 | 02:14 AM
memLT-1's Avatar
This is what I thought too.And also isn't there a strategy code on the tuner that tells you if it was changed?
Old Nov 9, 2007 | 06:25 AM
2TruckMike's Avatar
Well that does truly Suck!!....Is a reflash something the dealership would do each time truck comes in for service? Or just when they believe its needed?
I was about to order Troyer tunes via XCAL2 as well...but this thread makes me wonder if I should now...
Old Nov 9, 2007 | 07:27 AM
NKwish's Avatar
I am getting tunes on a new 07 and anticipate it will have to go to the dealer sometime under warranty. I found that the small cable type gun locks work great to lock out the port and they are usually free through local law enforcement. I told my service manager about it ahead of time and the reason why. He never gave me any trouble over in fact he was very interested in the the whole thing. You could always use the excuse that you like the way your truck runs now and you are one of those that believes that "if it ain't broke, dont fix it".
Old Nov 9, 2007 | 07:48 AM
INFireRedF150's Avatar
I know you have an OBD CAN vehicle but the other pins between your OBD port and mine should be relatively the same. I would love to be able to lock out the flashing and make the dealer come to me for an explanation. Then again I don't go to the dealer unless I have no other choice. Let me know what you find out but worse case I can go back to my tuner(1.5 hour drive) and get such a situation corrected but I would like to avoid such altogether if possible.
