Need Bill's help
Old Nov 27, 2007 | 05:37 PM
  #46
i.ride.suzuki's Avatar
Originally Posted by polpilot
so do you agree ASE? i had it about there and it seemed to rev to high before it shifted
I run @ 5300rpm on all shifts.
I would even go lower, but that means my downshifts get further apart, and i don't want that.
Old Nov 27, 2007 | 05:50 PM
  #47
polpilot's Avatar
I have a 2001 i think it might be a little diffrent then a 2006
Old Nov 27, 2007 | 06:56 PM
  #48
ASEMechanic's Avatar
The 4.6L doesn't make as much power in the upper RPM range as the 5.4L. Let me rephrase that... the power curve drops off sooner on the 4.6L than it does on the 5.4L. For this reason, I generally don't like to run the RPMs as high on the 4.6L because it doesn't really help.
With the vehicle being a 2001, you are also at a slight disadvantage as 97-03 models are about 10-15 HP shy of the later models.
Anyway, I usually go about 4900 on the 1-2 and 2-3 and about 4650 on the 3-4. You aren't too far off with what you have but you might lose a little trying to run out the top end of the RPM range.
Hope this helps.
Bill
Old Nov 27, 2007 | 07:13 PM
  #49
polpilot's Avatar
Hope this helps.
Bill
Thanks ill have to give that a try ill let you know how it turns out.
Old Dec 12, 2007 | 11:19 AM
  #50
2005lariatky's Avatar
Bump
Old Dec 12, 2007 | 12:59 PM
  #51
Ah, once again my brain has escaped me. I am looking over it now and will have something in a bit.
Bill
Old Dec 12, 2007 | 01:54 PM
  #52
malexander52's Avatar
Tell Me Tell Me Tell Me!!!!!!
gear 3.73 (changed from 3.08)
Hey Polpilot, I have the 4.6L with that bull$h|t 3.08 too and I have ordered my 3.73s. Please tell me what kind if difference you felt driving around town , taking off, and passing on the highway. Additionally did your in town mileage go up if you drive it easy? I'm excited because I have not encountered anyone here on the forum with the same engine/rearend setup as me that went to 3.73s. I don't want 4.10s, it seems too steep.
What are your critiques since you made the change?
Old Dec 12, 2007 | 11:57 PM
  #53
Question
Originally Posted by 2005lariatky
I updated my edge before the custom tunes and my truck felt as if it lost power, and when I added the custom tune it didnt feel any different. I was running i think ver 20 with firmware 22, maybe the other way around and the truck felt as if it had lots more power before the update. I didnt customize anything and the truck would break the rear tires and s**t and get it. LOL. What I am asking is what changes have been made in the updates that would have made my truck slower?
Okay, I compared the calibrations v21 vs.v28 and came up with only a couple of differences. They were basically centered around Open Loop Delay and I changed them to help resolves the shudder issues. They shouldn't have had that big of an effect on your power level though.
If you want to give it a try, I can send you the v21 calibration and see if you get the power back. I don't really see how it should make that big a difference, but I'm game if you are.
Let me know.
Bill
Old Dec 13, 2007 | 08:48 AM
  #54
Yes lets try that. Also whenever it stops raining and possibly snowing this weekend I can test that and a few custom settings. Also I have a K&N drop in filter on order if that will make a difference in any of the settings.
Old Jan 27, 2008 | 12:36 PM
  #55
kd4crs's Avatar
So what was the outcome from your comparison of the 2 calibrations?
Old Feb 8, 2008 | 02:51 AM
  #56
I dropped the ball on that one. I never did get him the calibrations. KY, if you're still interested, give me a shout and I'll get them to you and see if the power comes back.
Bill
Old Feb 8, 2008 | 08:18 AM
  #57
Yes that would be great!
Thanks!
