distilled water
Old Oct 16, 2002 | 03:29 PM
f-150_91's Avatar
Question distilled water
Hey guys,
Does anyone her use distilled water to wash there trucks??? I hear this can be a better way to wash and keep the swirl marks and microsctraches down. Tks for any advice
91
Old Oct 16, 2002 | 05:21 PM
Intel486's Avatar
Distilled water doesn't have any minerals in it, which means you don't have to dry your truck and you won't get waterspots.
Problem is if you need to find a place that sells distilled water or you need to distill it yourself. You then need a tank to carry the water to your house and a pump to pump the water for you to spray it.
I don't use distilled water. If I lived in a hot, dry climate where drying a vehicle before waterspots started was a problem, then I would consider it. Otherwise, drying your truck after you wash it is perfectly fine.
Old Oct 22, 2002 | 06:20 PM
Dennis's Avatar
It doesn't have to be distilled water. It can be deionized or reverse osmosis water too. RO water would be cheaper.
Old Oct 22, 2002 | 07:02 PM
f-150_91's Avatar
Tks guys for the info, yes it can get expensive and seem unpractical if you have to buy at the store. Maybe if my truck was newer I would use it, but it's gettin kinda up there still a good truck though Tks again guys, I'm still open to all suggestions
91
Old Oct 22, 2002 | 07:26 PM
Old Timer's Avatar
Hi F150
Thats a good question and would work.
Like Intel says...could be an expensive hassle.
Hey Dennis I see your aware of that RO water treatment. Did you ever see that ad sometime ago for a RO water filter attachment you hook up to hose?
It made for a streak free shine...car/windows etc. No toweling..wiping etc...price? As i recall it was under $40.00 but when i called the mfg....Question: How much water would it filter before plugging...forgot exact answer...but said it would probably last about 5 car washes.
Sure was a good idea..but thought to much $$ for no longer than it lasted. It wasnt around long.
I think our local DIY car washes here use RO water on one of the rinse cycles. It comes out real slow..eats up the minutes..but does a descent job on not leaving alot of water spots. Our climate is real dry here..Washing at home...man im tired after washing/drying my truck...water dries just that fast. So you have to be faster
Just tried Blue Coral Wash/Wax, not bad.
Good luck...OT
Old Oct 22, 2002 | 09:23 PM
Intel486's Avatar
f-150_91, where are you located?
Old Oct 22, 2002 | 10:25 PM
f-150_91's Avatar
I'm in Ohio, why?
Old Oct 22, 2002 | 11:25 PM
Intel486's Avatar
Originally posted by f-150_91
I'm in Ohio, why?
Just wondering.
