Removing scratch on driver side plastic door panel?
Old Apr 14, 2015 | 03:07 PM
CC268's Avatar
I have a small scratch from the dealer - most likely from people getting in and out of the truck and hitting their shoe on the plastic door panel.
I have no idea if this is something that can be removed or not? I have some Plastic X...not sure if that would work or not.
Old Apr 14, 2015 | 04:16 PM
We need a pic on this one. PlastX should be safe, I use it on a foam pad in a drill to do headlight lenses.
Old Apr 14, 2015 | 07:47 PM
2stroked's Avatar
As has already been said, pics would help a lot.
Are you talking the plastic panel on the inside of your door or the painted surface on the rocker? That'll make a huge difference in what you should do.
Old Apr 14, 2015 | 08:51 PM
CC268's Avatar
Plastic panel...you can see they are quite faint.
Old Apr 15, 2015 | 08:03 PM
2stroked's Avatar
I wouldn't use Plast-X on that. Plast-X is for use on scratched paint. What you have there is an scratched unpainted injection molded plastic panel. I'd try All Purpose Cleaner (let it soak for a bit), then agitate it with a stiff bristle brush. Follow that with something like Poor Boy's Natural Look Dressing.
Old Apr 15, 2015 | 08:05 PM
PlastX is for polishing and protecting plastic - you are thinking of ScratchX. But you are correct, I wouldn't use either on that.
Old Apr 15, 2015 | 08:42 PM
CC268's Avatar
Alright guys thanks I will try an all purpose cleaner on it. Not sure if I can get it out. If not its not a huge deal.
Old Apr 16, 2015 | 08:15 PM
2stroked's Avatar
Agreed, but not textured plastic.
Old Apr 16, 2015 | 09:59 PM
I thought I implied that by saying I would not use either PlastX or ScratchX on it........
Old Apr 23, 2015 | 09:37 PM
lowrider111's Avatar
Megs APC or Lexol can surely remove that.
Old Apr 27, 2015 | 11:35 AM
CC268's Avatar
Thanks for the help!
Old Jun 28, 2015 | 06:05 PM
daharley's Avatar
did you remove the scuff?
