Rubber Window Moulding?
I typically use Back-To-Black on my exterior rubber and plastic -- some guys around here pan it, but I've always had good luck with the product. I've used it religiously on my daily driver '97 Ranger since it was new, and the hard plastic and rubber is still in excellent condition on this vehicle.
To keep it looking good I'd highly recommend Lexol Vinylex Protectant. it can be found locally, usually at PEP Boys. The only problem with it is that it washes off pretty easily so you should apply it every time you wash.
Hey Slim
Lucky you ! I got a brand new 08' and the trim didn't even > start out < black ! It's like gray, with some funky, streaks of different colors like with rain water on a wet street :-(
I just bought some of that trim dye stuff from ADS though. Need to try that stuff today.... Will report back.
Peace,
Fish
to keep the rubber outline window moulding black?
Peace,
Fish
I noticed that when I picked up my '09, and it was the same on my previous few F150's... I asked the dealer what the heck they were thinking... he just said it drives him nuts too...
It really bugs me on my Platinum since it is all black and the grayish/oldish looking rubber really sticks out.
Okay, just reporting back on that stuff I got from ADS...
It's called "Showroom Restorer Black"..... and unfortunately, not surprisingly, it didn't work on my effed' up trim either :-(
On the first pass, it looks like it was going to, but as it soaked in, it started getting streaky, and as it dried, it looked worse than without it :-(
Next, I took some of the {hated by most} Ice liquid, and wiped over the trim, before the stuff was fully dry. That wiped off the black dye stuff (I could tell by how black the micro-fiber towel got) and made it look better than anything else.
Still only dark gray, with some streaking.... but better :-(
I HATE F150 trim rubber :-( Anybody that feels any different, has to have different trim rubber on their trucks. But then again, I hear from a fair number of other F150 owners (like Mickey above) who say the same stuff about their trim as I do. So, it's not just an isolated thing.
Fish
Fish
You might want to look into Megs # 39 & #40. ADS sells both.
Fish
Fish
To the OP, for your 09, just hit it with BlackWow....you'll be impressed....lasts for a VERY long time...
After you apply it, dry buff it off, and you're done...a little goes a long way and once treated with BW you can simply use something like HD to keep it up even longer
BW works extremely well. I'd give that a shot before using the Showroom dye product. For you 09, it cannot be that bad.
RR
RR
Thanks RR... I'm going to give BW a shot! I found it on Amazon.com for $25... is there anywhere local (noticed you are in North Tx) that carries it for a similar price?
http://www.amazon.com/Black-WOW-Exte.../dp/B00144FZUG
You would be surprised how bad the '09 is off the showroom floor, it stood out for sure. We've got an Expedition as well, so I'll be using the BW on it as well...
Ya' know Clambelly, with all due respect, I don't think so.
This whole effed' up F150 trim thing, is something which a good % of owners can totally relate to, and the rest (with normal trim) just have no idea what we are trying to explain.
I'm telling you, my trim (and apparently many others) was screwed up straight from the factory, and I'm not so sure their is a product which could possibly fix it :-(
Peace,
Fish
PS, I'd REALLY love to try that Black Wow..... But I have SO little confidence that it would help my factory effed' up trim, and I'd be pissed if I spent $25 on the stuff, only to find out I threw away $25 and my trim still sucked ****....
Peace,
Fish
Well hey Mickey, I'm really anxious to hear how that works for you. Since it sounds like your trim is just as troublesome as mine, if that Black Wow actually works for you, I guess I'd have to consider it myself.
Best of luck,
Fish
Best of luck,
Fish
Peace,
Fish
Peace,
Fish
Follow up with the same procedure a few days later, and you can even do it again a few days later after that.
It will NOT make your trim nice and shiny like it was just dressed because it is a Dye, not a dressing. It will however dye your trim black and then make it ready for a dressing to be applied to make it shiny. This is when you could use Black Wow, which will keep it shiny and enhance it's depth of color.
