I love Hyperdressing
Old Jul 14, 2009 | 04:19 PM
and I love my nicely taken cared for 2004 underbody
HD ratio 3:1, wheel wells, frame, and tires.
Dirty
Cleaned
Dirty
In-Process
Cleaned
I wish I had money for some more modifications, such as my taillamp smoking project, third brake light project, XD wheels and Cooper STT tires ( my tires are not real safe )
And for kicks, a shot of the 11" Magnaflows after 1yr 10 days of being on the truck. The Pennsylvania winter pitted the T-409 surface a little bit but still looks alright. Not worried about it rusting out anytime soon because I have been considering a muffler change sometime soon when money's better, and the potential buyer for the 11"s is down where no snow goes so it works out.
Old Jul 14, 2009 | 04:25 PM
SKATERBRO's Avatar
It is good stuff. I love how it smells and how it seems to spread itself out. Did you use that foaming sprayer for tire application? When i would spray HD directly onto the tire it seemed like i was using way too much. I prefer using a tire applicator with HD sprayed on it.
Old Jul 14, 2009 | 05:21 PM
esf's Avatar
esf
This is how I've been applying it. Not because of fear of using too much but because it's anooying to have to go around and wipe my wheels down afterwards.
It looks good! Maybe I should climb under and check out my Magnaflow.
Old Jul 14, 2009 | 08:47 PM
4wd150's Avatar
looks good Darren
Old Jul 14, 2009 | 09:43 PM
abervintageman4's Avatar
did you dilute it at 4:1?
Old Jul 14, 2009 | 09:54 PM
Thanks for the comments everyone. I just shoot the tires with HD, and wipe it down with a foam pad and then re-wipe them with a MF towel.
nope,
HD ratio 3:1
Old Jul 14, 2009 | 10:10 PM
mntnbike1's Avatar
HD is great stuff. I'm addicted to the smell as much as how well it works. I just keep spraying. I think Meguiars need to make air fresheners.
Old Jul 14, 2009 | 10:44 PM
31 YNOT's Avatar
i use 1to1 on my tires and stuff on the out side of the truck, makes it SHINEY and 4to1 on the inside which puts a real nice shine there too. I should snapped some pics of my dads truck after i did a quick detail on it
Old Jul 14, 2009 | 11:40 PM
Lookin good bud
Old Jul 15, 2009 | 07:45 AM
BigNate's Avatar
I am not sure I like the results.
Does it last through a wash or two???
And it is a little spendy.
Old Jul 15, 2009 | 01:19 PM
No, its just to be applied after every wash to keep a gloss, satin, or flat finish. I prefer to keep a flat finish. I hate glossy tires.
Old Jul 15, 2009 | 01:43 PM
I'm addicted to glossy tires
Old Jul 15, 2009 | 04:29 PM
esf's Avatar
esf
I've had it last quite a while. It actually will build up on the tires if you use it every wash and don't clean the tires with a good APC and stiff brush. The tires probably could have been cleaned a little bit better. In the application picture it looks like there was still dirt on the tires. For best results you should get the tires as clean as possible. I also realize those tires are pretty beat. HD is my go to product for tires and wheel wells however I am currently playing around with Optimum's Opti Bond Tire Gel. It's also not as spendy as you think. If you dilute 4:1 you're essentially getting 5 gallons for less than $40. And it can do a multitude of things from interiors (door panels, dash board, etc), undercarriage (wheel wells, frame, etc), tires, trim...
Old Jul 15, 2009 | 05:11 PM
SKATERBRO's Avatar
...... and just as important, engine bays. When used under the hood it can last over a month easy.
Old Jul 15, 2009 | 06:50 PM
pmason718's Avatar
Check out this thread D for your lights
https://www.f150online.com/forums/pa...light-set.html
ESF does ADS have a stiff brush for cleaning wheels that you recommend?
