DWV Intake Mod for 2004-2008 F150 with 5.4L Engine
Old Jun 26, 2010 | 03:11 PM
  #121
EdR's Avatar
EdR
Made a DMV intake. really easy But It seemed to me like MPG suffered alot. ran it for 2 weeks . Switched back to stock set-up.No need to lose Mpg for a little more power.
my 2 cents
Ed
Old Jun 26, 2010 | 03:19 PM
  #122
Barrett's Avatar
You should not lose mpg from this mod, did you get your mpg figure from the computer on the dash or by hand?
Old Oct 14, 2010 | 06:23 PM
  #123
Adrnlnjunky's Avatar
Or are you stepping on the gas more because you can hear the intake??
Old Oct 14, 2010 | 06:39 PM
  #124
fine_style150's Avatar
^ they cause a little whine so for some members to claim they have lost mileage is because a 10 dollar intake just bought a little excitement to the plain ol 5.4
Old Oct 26, 2010 | 11:55 AM
  #125
Silver T's Avatar
Has anyone done this mod lately? I went to my local Lowe's and they did not carry part number 23455. They did carry a downspout adapter that I believe would work, but not 100% sure on it. When any of you did this did it take some stretching to get that rubber downspout over the coupler?
Old Oct 26, 2010 | 03:10 PM
  #126
che22879's Avatar
avoid all that and do it this way https://www.f150online.com/forums/ar...04-2008-a.html
I did and couldn't be happier with the results!
Old Oct 28, 2010 | 10:45 PM
  #127
WHITESAND's Avatar
did this today, had no problem finding the parts, sounds better may have made a little difference not sure yet.
Old Dec 27, 2010 | 10:38 AM
  #128
06TrueBlueScrew's Avatar
Originally Posted by FullerF-150
So i did this mod, and now im idling at around 500 rpm.. is that normal with this intake? im running a stock 04. btw, this is what mine looks like installed..
What did you use to fit into the fender area? Looks like you did something different. Is is possible to use this cuff:
http://www.stylintrucks.com/part.asp...5&scid=FROOGLE
Then just use ABS pipe between the baffle and this fender cuff?
Old Dec 27, 2010 | 11:21 AM
  #129
BigTerp's Avatar
I agree. I originally did the mod with the downspout coupler etc. But found it didn't fit very far into the fender wall. I have also heard of people saying the rubber coupler has actually folded into itself from the suction of the intake. After doing it with just the DVM pipe that I had left over, I was able to get the pipe into the fender wall just as far as the stock intake hose was.
Old Dec 28, 2010 | 08:27 AM
  #130
Anyone? Can I use that cuff to put in the fender or not? Somebody should update the material list for this mod cause I've read the whole thing 5 times and it changes on every page. I want to do this mod, but I would rather not grind down ABS pipe and I don't want a rubber adapter that gets sucked in.
Old Dec 28, 2010 | 04:06 PM
  #131
kd4crs's Avatar
There is a revised version of this mod that I posted in post #74 of this thread. You may want to look at doing that one if you have concerns about the downspout connector deforming or getting sucked inside out. Linky below:
https://www.f150online.com/forums/3818781-post74.html
Old Dec 28, 2010 | 06:16 PM
  #132
^^ kd4crs thanks for the post reminded me to thank you for the idea, much cleaner install then using a pvc pipe
Old Dec 28, 2010 | 06:24 PM
  #133
kd4crs's Avatar
You are quite welcome. I am always happy to help.
Old Dec 29, 2010 | 08:45 AM
  #134
Yep, I got this done right with the Spectre intake kit as well. Looks very clean, no ABS pipe grinding or other hassles. Mine looks exactly like this: https://www.f150online.com/forums/3818781-post74.html
Thanks kd4crs and FullerF-150 for the answered PM's.
Old Jan 7, 2011 | 12:41 PM
  #135
kixcastillo77's Avatar
Hi, I'm new here and had one quick question...can I do this mod on my 4.2? Its a 2007 and I've seen it done with PVC but I like the look of the Spectre tubing better. Would this be possible? Also, do MPG's suffer because of this? I've read mixed opinions, thanks!
