can i spray paint my emblems black?
Old Dec 24, 2009 | 03:54 PM
sandiegosurf's Avatar
so i just used the forum search and couldnt find what i was looking for..
i want to black out all the ford emblems on my truck (front and back ovals and side rectangle f150 emblems) and want to know if i can just do some light sanding and tape off the area around the emblems and spray a coat or two of black spraypaint over them and maybe clear coat them? would that be a good idea? if so, would any spray paint be good?
Old Dec 24, 2009 | 03:56 PM
Cuz's Avatar
Cuz
I don't know why you couldn't.. Just sand them with a very high grit paper and make sure to clear coat em.
Merry Christmas!
Old Dec 24, 2009 | 04:04 PM
thanks! merry xmas to you too!
Old Dec 24, 2009 | 04:52 PM
mcwilly's Avatar
Yes, it can be done. Scuff them up first then follow it w/ paint. Most people on here (myself included) use Krylon Fusion (spray paint for plastic) satin black.
Old Dec 24, 2009 | 05:32 PM
grassmanfx4's Avatar
Krylon fusion is the way to go. Post pics when your done.
Old Dec 24, 2009 | 05:43 PM
mblouir's Avatar
The best way would be to remove them and paint them off the truck to prevent overspray. It's not hard to take them off (a little heat and some fishing line) and it only takes some 3M emblem tape to put them back on.
If you don't want to take them off then yes, you can mask off surrounding areas. Mask off more than you think you need, though, and be sure to tape down the newspaper on all sides. Scuff with some sandpaper and use Krylon Fusion like everyone already suggested. Put some clear coat over that, too, and don't touch it for a day or you'll have some nice fingerprints on your freshly painted emblems.
Old Dec 24, 2009 | 08:04 PM
alright well i jus sprayed two coats over the emblems and they look pretty good. the front ford oval emblem kinda started to peel when i sanded it. there is like some film over it or something, i donno. how long until i should spray the clear coat over it?
Old Dec 24, 2009 | 08:13 PM
mblouir's Avatar
Did you wet sand them? If not it may have been pretty abrasive on the front oval--hence why it peeled. No biggie, though, since you're painting it.
Generally I wait about an hour after the color coat before applying clear over it.
Old Dec 25, 2009 | 01:53 AM
eastcoastzigzag's Avatar
------heat as in heat gun? then i assume just run fishing line under the emblem. i want to paint mine but have no interest in painting them on my truck. i was contemplating buying new emblems but i have no idea on the cost. maybe a 09's, iduno.
this are purely adhesive emblems? no posts in the back?
Old Dec 25, 2009 | 09:53 AM
mblouir's Avatar
A few of the emblems have posts on the back so the truck does have holes there. It is purely adhesive, though, so you can pry them off with a heat gun and fishing line. Just work around the posts. The 09 emblems will work, but there are some modifications people have done to theirs. Can't remember the details but a quick search should give you what you're looking for if you're thinking about switching to 09 emblems.
The only one that isn't held on by adhesive is the front oval, which is bolted through the grille. Pop the hood and you will see the two nuts you have to remove.
It's not difficult at all to remove them and put them back on.
Old Dec 25, 2009 | 01:37 PM
IDNC76's Avatar
Old Dec 26, 2009 | 02:28 AM
Yogi.kudos's Avatar
Did you paint those yourself IDNC?
Im planning on painting mine soon because the F150 lettering is chipping away.
Old Dec 26, 2009 | 11:15 AM
IDNC76's Avatar
yeah ,sanded the chrome off, used a plastic primer spray paint , than a few coats of a black satin spray paint.
then the inlays i got from patriotdecals, they are a pita to put on the 09 emblems , as you can see they are not perfect, but im satisfied.
Old Dec 29, 2009 | 10:24 AM
Mayor_of_Preece's Avatar
Take a look at this thread...
https://www.f150online.com/forums/ap...lays-pics.html
