underglow
Old Oct 19, 2008 | 03:31 PM
hamster117's Avatar
Cool underglow
ok so i have a 4.2L '01 f-150 xl and im wanting to install an underglow, i was wondering if there was anything i needed to put in first
better alternator?
anything?
Old Oct 19, 2008 | 04:12 PM
Arca_ex's Avatar
I heard if you bought neons right now, you get three free stickers good for +30FWHP each, and a half off Folger's Custom Exhaust coupon.
Old Oct 19, 2008 | 04:39 PM
DanF150's Avatar
Old Oct 19, 2008 | 05:56 PM
trublueFX4's Avatar
Dont forget the free Year' supply of rice!!
Old Oct 19, 2008 | 05:59 PM
trublueFX4's Avatar
to answer your question, no you dont need anything else.
... maybe some mud guards to protect rocks from kicking up and breaking them
Old Oct 19, 2008 | 08:33 PM
Ricing out a F-150 is a sacrilege.
Old Oct 19, 2008 | 09:37 PM
Not my style at all, but if its a street truck it could work. Your battery and alternator should be fine.
Old Oct 19, 2008 | 10:58 PM
Arca_ex's Avatar
Noooooo.
Real street trucks DON'T have underglow. Unless you're a ***.
Old Oct 20, 2008 | 12:06 AM
The output of the alternator is fine.
You might want to invest in a Optima Yellow Top battery. They are a great deep cycle battery, especially if you want to run the underglow with the engine off for long periods of time without destroying the battery.
Another suggestion would be to make sure you fuse! Fuse ALL connections to the battery! You don't need to see you truck burst into flames if there is a short or if water messes up a connection. I had a close call 2 weeks ago when I had a wire short out, but it was fused, but not the right type for the load.
I recommend using 12 to 14 AWG twisted-braid copper wire, and use top-of-the-line BUSSMAN fuse holders and BUSS blade fuses. I'd solder all connections, and heatshrink them ALL. Get a decent toggle switch with GRD, ACC, and PWR. If it's a lighted switch, you will need to make sure the GRD and is connected on the switch. If you don't want it to light, you can skip the GRD, and directly GRD the ACC, being you underglow lights.
Also, watch for load considerations. Make sure you don't parallel too many lights together, and wind up having an overdraw, which is kind of hard to do, but it's completely possible, which is also bad. If need be, separate the lights, and have 2 or more switches for load balancing and equilization.
Just some suggestions if you do heavy lighting.
Old Oct 20, 2008 | 12:23 AM
NoLongerJeepin's Avatar
Don't do it. That's all I'm going to say. I'm tired of trying to keep rice off of these beautiful trucks. It's an up hill battle.
And you don't need a new battery or alternator or any of that stuff Manual"cantgetagirl"F150 said. Just fuse it and get a decent switch.
Old Oct 20, 2008 | 02:31 AM
Lord Helmut's Avatar
if you are gonna do that make sure you install the l.e.d version of the underglow, there brighter , tougher and they last longer. Ive installed them myself on my Dakota (and yes it was a street truck) The only problem you may face is that the wires connecting the lamps to the module may not be long enough. Look into that before you purchase them. Also to properly mount them you two extra lamps because you cant mount them where the cab changes to the box, there is too much flex. Any other questions just let me know
Old Oct 20, 2008 | 09:17 PM
Chris04v6's Avatar
i have them on my truck.
be tasteful with them, and you will look great.
yes to two extra lamps, too much flex and not enough lighting for that long truck! i have a reg cab and i had to put on six lamps to totally light up the undercarriage
Old Oct 20, 2008 | 10:33 PM
4.6 Punisher's Avatar
Under carriage neons are generally a no-no, unless you live in California.
Old Oct 20, 2008 | 10:46 PM
trublueFX4's Avatar
they arent cool in California anymore either
Old Oct 20, 2008 | 10:51 PM
JackandJanet's Avatar
We're not even seeing them in Tucson anymore, on any vehicle!
- Jack
