xentec HID kit
Old Feb 17, 2008 | 09:07 PM
  #121
NoLongerJeepin's Avatar
hmmm. did your stock lights flash when you unlocked the doors? when the HIDs initially turn on the jump (about 25000-50000 volts) ignites the gas then it takes a very low draw to maintain the light. what is probebly happening is when you unlock and they turn on its gives the first one just enough juice to ignite and the second one gets about half what it needs. this is strickly theory but it makes sense in my tiny little brain
Old Feb 17, 2008 | 09:08 PM
  #122
Jditta's Avatar
sounds good to me. dont matter, they work when i turn them on thats all that matters.
Old Feb 17, 2008 | 09:25 PM
  #123
Buckeyes's Avatar
that makes sense to me too.
Old Feb 17, 2008 | 09:35 PM
  #124
ok good just wanted to make sure i wasnt going crazy
Old Feb 17, 2008 | 10:31 PM
  #125
mSaLL150's Avatar
wooooohoooooooo!
Old Feb 17, 2008 | 10:34 PM
  #126
hot damn son thats alot of light!
Old Feb 17, 2008 | 10:36 PM
  #127
Jditta's Avatar
nice msall. where did you mount the ballasts for the fogs?
Old Feb 17, 2008 | 10:55 PM
  #128
mSaLL150's Avatar
next to the frame by the tow hooks theres an indentation where they literally fit perfectly snug. it was like Ford made these slots specifically for ballasts.
Old Feb 17, 2008 | 11:47 PM
  #129
Jditta's Avatar
sweet man. did u get my pm about that audio question i asked?
Old Feb 18, 2008 | 12:32 AM
  #130
mSaLL150's Avatar
my bad, i sent you a reply.
Old Feb 18, 2008 | 08:16 AM
  #131
gilsnuxs's Avatar
well i just bought this kit last nite so hopefully all is well.
http://cgi.ebay.com/ebaymotors/ws/eB...222893555&rd=1
i think that they well go well with my Hella heads
Old Feb 19, 2008 | 12:23 PM
  #132
Ray21's Avatar
I installed my kit over the weekend... install went pretty well. They are flat out bright! I was skeptical but am now impressed.
Does anybody elses switch from low to high before shutting off?
Old Feb 19, 2008 | 08:56 PM
  #133
mSaLL150's Avatar
Yes it is just the internal solenoid straightening. All the Xentec Bixenon kits do this.
Old Feb 20, 2008 | 12:55 AM
  #134
jspeers89's Avatar
With the HID kit the lights flicker because of the power needed to ignite. I have the same kit. If you hook up a relay it will distribute the power when you unlock your doors and eliminate this problem. I do not know all the specifics and my electrical friend helped with my install but explained it to me briefly. They are gorgeous lights for our trucks and really are the best appearance mod.
Old Feb 20, 2008 | 02:03 AM
  #135
recon_sct's Avatar
Registered User
I have a question for you guys running Bi-xenon kits (hi and lo beams) How do like the output of the high beams? My low beams work fairly well but when I turn on the high beam they point straight to the ground! I thought I might have the bulbs in upside down but tore everything apart and they are in right (only one way to go in) I checked to make sure the bulbs are working properly, when on low beam the lights are straight and when I hit the high beams the bulbs telescope up. Not sure whats going on, but thought maybe one of you would have run into this.
Thanks for any help!
