xentec HID kit
Old Feb 16, 2008 | 10:12 PM
  #106
MmmBuckles's Avatar
Originally Posted by NoLongerJeepin
just wait till your driving down the freeway and all the exit signs light up. its freakin sweet. i just installed a kit on my brothers audi and he loves them
its amazing. all the license plates and street signs glow now. and whats nice is i havent been flashed once. i thought i would be seeing hi beams all the time after i installed them, but i guess they are at the perfect height that it doesnt bother ppl
Old Feb 16, 2008 | 10:16 PM
  #107
NoLongerJeepin's Avatar
mine are the same way, i put out a ton of light and i never get flashed
Old Feb 16, 2008 | 10:18 PM
  #108
MmmBuckles's Avatar
funny thing is, when i have my fogs on, i get flashed all the time and they are half as bright as my HIDs
Old Feb 16, 2008 | 10:34 PM
  #109
iv gotten flashed when i have my fogs on once. but it was by some slammed honda so i didnt take much notice to it
Old Feb 17, 2008 | 07:46 PM
  #110
Jditta's Avatar
I got all my stuff installed but theres one thing, it says my high beams are on(like on the dash, the blue hihgh beam indicator is showing uop). well i turn on the brights and the lights go off, which i expected bc i dont have high beams now. asnyone know y the light might be on inside?
Old Feb 17, 2008 | 07:52 PM
  #111
something screwy happens to the highbeam grounding system when you install hids. its worse in people with fog lights and hi/lo kits. the solution is to provide a constant ground to the highbeams. you can do this by following http://www.landstromsfoundry.com/Tec...Foglights.html this. it should return the system to stock. the only differance is that you run highbeams and fogs at the same time
Old Feb 17, 2008 | 08:06 PM
  #112
Jditta's Avatar
I might go to fogs also. whihc do i turn the hex screw on the headlights to aim the lights up? They are aimed pretty low right now.
Old Feb 17, 2008 | 08:17 PM
  #113
yeap turn the hex screw sticking out of the back on the light housing to the right to aim up left to aim down. i would def recommend HID fogs. its awsome how bright they are together
Old Feb 17, 2008 | 08:20 PM
  #114
Jditta's Avatar
The kit is grerat, but the prongs on the connector cables didnt fit into my stock light harness so i had to do some modifications to make them fit.
Old Feb 17, 2008 | 08:31 PM
  #115
where did you endup mounting your ballist?
Old Feb 17, 2008 | 08:47 PM
  #116
Jditta's Avatar
One on my heat shiled of my air force one, and one on the washer fluid case thing. NOt the greatest places but they were flat and easy acess. The damn prongs gave me the most trouble,.
Old Feb 17, 2008 | 08:48 PM
  #117
were the prongs in an h13 connector?
Old Feb 17, 2008 | 08:56 PM
  #118
Jditta's Avatar
Yea, they just didnt fit in the stock light harness. they were too thick. ended up breaking them and had to just rig it my way. when i hit the unlock button on my fob, the passenger light flickers and doesnt come on. but the lights work when i turn them on???
Old Feb 17, 2008 | 08:58 PM
  #119
what do you mean th lights work when you turn them off?
Old Feb 17, 2008 | 09:02 PM
  #120
Jditta's Avatar
What? I said when i hit the unlcok button and the lights come on, one side works and the other side flickers, but doesnt come on completely. But when i actually turn the lights on they work.
