xentec HID kit
Old Mar 4, 2008 | 10:19 PM
  #151
MmmBuckles's Avatar
Originally Posted by IDNC76
can you guys help me out, i just purchased the xentech kit from hid4u off ebay and the 9005's plugged right up, but the h13's you have to stick these to prongs into the stock harness, how did u do it, they wont fit,should i try and trim them down and stick em in there, and tape it up good??
and which prongs go where ???
thats what i would do. red should go in the middle hole. and the black in the right side hole
Old Mar 6, 2008 | 01:39 PM
  #152
IDNC76's Avatar
it was quite easy. i used pylers and just smushed the prongs till they fit i stuck the black in the middle and the red on the right. it works fine, but the high beam icon is lit up, on my gauge cluster. i ll have to give it a re wiring later to figure it out.
excellent kit though, everything lights up at nite, its amazing, i love driving at nite now
Old Mar 6, 2008 | 02:43 PM
  #153
mSaLL150's Avatar
Sweet! Glad you figured it all out.
Old Mar 6, 2008 | 04:29 PM
  #154
IDNC76's Avatar
yeah, thanks for all your help man
Old Mar 11, 2008 | 03:01 PM
  #155
IDNC76's Avatar
does anyone elses lights flicker when u hit the open button on ur remote??? or did i wire wrong??
Old Mar 11, 2008 | 04:09 PM
  #156
attworth's Avatar
Sounds like you've got them wired into the wrong position bud.
Old Mar 11, 2008 | 04:11 PM
  #157
attworth's Avatar
Yeah somebody explained it already. It takes a good deal of power to light these up, then they take very little draw to run. When you press the remote button its giving just enough to slightly light them up but not enough to light em fully.
Old Mar 13, 2008 | 05:42 PM
  #158
Texasflawlessme's Avatar
ive ordered a few from Hid4u and they came in wrong colors
Old Mar 15, 2008 | 10:02 PM
  #159
gilsnuxs's Avatar
well i finally got mine in the Hella heads. looks good, but i need to aim them down. they are all over the place right now.
Old Mar 16, 2008 | 02:16 PM
  #160
NaptownF150's Avatar
Exclamation Weird Issue with HID Headlights
Guys, I hope you can help. I ordered the bixenon H13 kit from Flashplus, and got a plug that would not work with my headlights. So I came on here and found another thread where someone had the same problem. I cut the plug from the kit and the OEM headlight light plug, and spliced everything together. Everything works, but when I turn on the (stock) fog lights, the HID's move into a middle position between high and low. I'm pretty sure this will cause some issues with blinding people.
Anyone else have this problem?? With the fog lights off, everything works perfectly, but the minute I turn the fogs on the headlights move into some weird middle position.
Thanks!
Old Mar 16, 2008 | 03:54 PM
  #161
NoLongerJeepin's Avatar
the problem you are having is the fog lights sharing a ground with the high beams. you need to provide a permanant ground for the fog lights. follow these instructions http://www.landstromsfoundry.com/Tec...Foglights.html
and it will fix the problems. good luck!
Old Mar 16, 2008 | 06:51 PM
  #162
Will do, I'll let you know how it goes.
Old Mar 19, 2008 | 08:06 PM
  #163
sampson01's Avatar
just installed my set of 10000k pics will follow
Old Mar 19, 2008 | 08:11 PM
  #164
mSaLL150's Avatar
Damn 10000k is so blue. You're not gonna be able to see chit in the rain.
Old Mar 19, 2008 | 09:05 PM
  #165
IDNC76's Avatar
yeah, glad i went with 6000k vs 8000k 6000k have just enough blueish tint for me
