xentec HID kit
Old Feb 20, 2008 | 02:07 AM
  #136
mSaLL150's Avatar
Originally Posted by recon_sct
I have a question for you guys running Bi-xenon kits (hi and lo beams) How do like the output of the high beams? My low beams work fairly well but when I turn on the high beam they point straight to the ground! I thought I might have the bulbs in upside down but tore everything apart and they are in right (only one way to go in) I checked to make sure the bulbs are working properly, when on low beam the lights are straight and when I hit the high beams the bulbs telescope up. Not sure whats going on, but thought maybe one of you would have run into this.
Thanks for any help!
No clue man, mine work flawlessly.
Old Feb 20, 2008 | 02:09 AM
  #137
recon_sct's Avatar
Registered User
For the guys saying they are getting flashed when they have their fogs on. I read somewhere thats pretty common because there is nothing sitting in front of the bulb like in the headlight housing. To fix that they took some aluminum foil and wrapped that around the front of the light to knock down the glare.
Just someone else's fix I thought I would throw out there. I try and find the post that had that.
Old Feb 20, 2008 | 12:28 PM
  #138
Ray21's Avatar
Originally Posted by mSaLL150
Yes it is just the internal solenoid straightening. All the Xentec Bixenon kits do this.
Thanks for the info... I wasn't sure if I had them wired up correctly.
Old Feb 20, 2008 | 01:34 PM
  #139
NoLongerJeepin's Avatar
sweet!
Old Feb 20, 2008 | 03:04 PM
  #140
recon_sct's Avatar
Registered User
Originally Posted by Melovidov21
I installed my kit over the weekend... install went pretty well. They are flat out bright! I was skeptical but am now impressed.
Does anybody elses switch from low to high before shutting off?
I this how they are suppose to work? Mine do not do this. I might try and change the wires around and see if that helps my problem with the hi lo thing.
Old Feb 25, 2008 | 02:33 PM
  #141
gilsnuxs's Avatar
well i finally got my kit in this morning. hopefully after i run my errands i will get them in with my hella heads since i got thge day off. pics to follow
Old Feb 25, 2008 | 08:34 PM
  #142
gilsnuxs's Avatar
well i was trying to install my HID's but i think i may have gotten the wrong kit, and now i lost my low beams on my passenger side. Highs still work. Any suggestions?
Old Feb 25, 2008 | 10:08 PM
  #143
Midnight05's Avatar
hey Melovidov21, what color did you get?
Old Feb 26, 2008 | 12:23 PM
  #144
Ray21's Avatar
Old Feb 26, 2008 | 06:42 PM
  #145
Midnight05's Avatar
i have been debating between 6000K and 5000K and i think you just made up my mind on that.. thanks buddy
Old Mar 4, 2008 | 04:35 PM
  #146
krazyballer's Avatar
How come most of the bulbs are for low beam,i cant find 9004in high/low or do all the kits for high/low
Old Mar 4, 2008 | 04:38 PM
  #147
mSaLL150's Avatar
i doubt those old f150s havea single bulb for both high and low. all chevys are like that. Just get a regular HID kit for you bulb type, it will be brighter than your current highbeams by 3x.
Old Mar 4, 2008 | 04:42 PM
  #148
yea hah they are single bulbs, i have sylvania's in there now.
Old Mar 4, 2008 | 04:53 PM
  #149
MmmBuckles's Avatar
they will be like a million times better than those cool blues
Old Mar 4, 2008 | 08:38 PM
  #150
IDNC76's Avatar
Exclamation
can you guys help me out, i just purchased the xentech kit from hid4u off ebay and the 9005's plugged right up, but the h13's you have to stick these to prongs into the stock harness, how did u do it, they wont fit,should i try and trim them down and stick em in there, and tape it up good??
and which prongs go where ???
