problem with system.
Old Apr 10, 2009 | 05:52 PM
  #46
JJDH's Avatar
meter is fine. mine set to ohms, when not touched reads ol or infinity, when i touch em it says0.1 or a little resistance, if ur checking your power wire for a short, do how i explained above, set meter to continuity, is this meter digital, if so it has a ringer on it, a good wire will ring, a shorted wont,little less difficult way
Old Apr 10, 2009 | 05:57 PM
  #47
ltz400racer's Avatar
yes it is digital.. its a actron cp7672
which setting would be continuity, i know its just a low resistance test, but i dont remember which it is. thanks! also can you clarify what exactly it is your asking me to do with the wires?
Old Apr 10, 2009 | 06:04 PM
  #48
JJDH's Avatar
page 3 number 41 42 i added to this thread, continuity should have a round dot with a few sound wave looking lines like .))) kinda like that, or on ohm setting do how i described on previous page
Old Apr 10, 2009 | 06:07 PM
  #49
JJDH's Avatar
also open line or [ol] means alot of resistance, touching leads together says.. .01 or zero, means low resistance thats y urs says zero
Old Apr 10, 2009 | 06:12 PM
  #50
hmmm no red dot, or waves...
and if i read your post correctly, you want me to get some extra wire, and make a circle with the power wire. is that correct?
Old Apr 10, 2009 | 06:20 PM
  #51
JJDH's Avatar
yes the only way, [that i have ever done or heard of ] is u have to have a complete path through your wire to meter to check continuity or resistance, or to check for a short is to place one lead on one end, and other lead on other end, to see if u have a short, if this is what you are trying to accomplish, this would be the only way. so without taking out ur power wire from truck, get another piece of wire,, tie to end under hood, after fuse, then put meter leads on each opposite end of wire, a short will have a very high number or OL. a nice path will say zero,or .1,,.2.. .3........something low, or a low resistance, a short causes alot of resistance, higgggggghhhhhhhhhhh number.
Old Apr 10, 2009 | 06:21 PM
  #52
JJDH's Avatar
also u can try it on a short line first to get to know how your meter acts. not all multimeters are created equal
Old Apr 10, 2009 | 06:27 PM
  #53
JJDH's Avatar
bump
Old Apr 10, 2009 | 06:49 PM
  #54
ARCuhTEK's Avatar
Just posting pic of his meter in case anyone wants to know what he is looking at...
Old Apr 10, 2009 | 06:52 PM
  #55
ARCuhTEK's Avatar
ya, no kidding have know clue how you found that so fast! i searched on google about 10 different times for it, but i never thought about going to crutchfield for it.. i forgot they had those on there. thanks .
I went on Google and types in your amp mfr name, model number and the words "owners manual".
It was the second link that came up.
Old Apr 11, 2009 | 12:44 AM
  #56
ya, thats exactly what im looking at! haha and im extremly confused by it.. i guess thats what i get for buying a cheap volt meter.
anyways, jj, so i just ground it anywhere that is bare metal, correct? or do i stick both leads on both ends?
im going to do this tmmrw at work when i get time. ill post the readings as soon as i get done.
Old Apr 11, 2009 | 04:10 AM
  #57
JJDH's Avatar
no grounding. in the cab u will have 2 wire ends, one big horseshoe. one lead goes on one end. red lead on other end, basically u are applying the meters voltage to the line, just re-read the posts
Old Apr 11, 2009 | 10:48 AM
  #58
ARCuhTEK's Avatar
It would have been faster for one of you to fly to his hometown and check the meter.....lol
Old Apr 11, 2009 | 10:49 AM
  #59
oh, i gotcha.. so then low numbers means its good, high numbers mean its shorted out..
be back later with my results.
Old Apr 11, 2009 | 10:50 AM
  #60
haha hey now!!! it was friday night, im young, i went out. haha
