Mounting Amps under seats vs behind rear seat on SCrew?
Old Dec 8, 2008 | 03:27 PM
  #31
alexarizpe's Avatar
behind the rear seat is fine i have mine mounted back there
Old Dec 8, 2008 | 06:32 PM
  #32
jrfonte's Avatar
Originally Posted by Low_e_Red
So, you are telling me that the old KS series Kicker amps were bad because they discontinued them? The old MBQ's must have been straight horrid because the ORIGINAL MBQ went bankrupt? etc.
And if they are that bad why have mine lasted 5 years without a hitch or a missed beat? Why are they still in immaculate shape? Why, when I am overpowering them as well? Please educate me.
Might it have something to do with you "think" you know how to set your gains properly? Cause I dont mind educating you on the correct method. Might it have something to do with cranking the tweets on them or on the deck?
Keep it coming, Im in for running this one in circles.
actually sweetheart it aint because they suck i actually like them alot and no i didnt have the gains set wrong or the crossover points the problem with them is fords fault because they designed a crappy 3rd brake light that leaked in rainwater all over my amp and made it short out causing the tweets to fry im just pissed at jl because they dont carry them anymore and i cant seem to get them to fix them for me
Old Dec 8, 2008 | 09:38 PM
  #33
mSaLL150's Avatar
LOL. good response. I love noobs.
Old Dec 8, 2008 | 11:42 PM
  #34
jump n's Avatar
Wink
My wife seems to make up for your lack of periods.
Old Dec 9, 2008 | 02:17 AM
  #35
mSaLL150's Avatar
Hmm...well after 4 years of abuse, mud, and rain i pulled my 3rd brake light out, tinted the crap out of it, then put it back....and after 1.5 years of more rain, more intsense abuse (because of lift and mudders) etc, it still stands strong, doesn't leak, and all of many amps STILL run super strong...
Maybe you should do your mods yourself....i've done EVERYTHING MYSELF besides bending/welding exhaust pipes....
Old Dec 9, 2008 | 02:40 AM
  #36
Low_e_Red's Avatar
AND I QUOTE
no there dayton audio titanic mkIII's the seats i had custom made from a company in dallas tx they are for the front they didnt make brakets for the rear to mount them so i had to make my own when i save up another $1200 im going to replace the front to match if i can figure out how to mount the factory seat belt air bag sensors under them so they work right. are you talking about the dayton refernce ho from parts express? just curios see a lot of reference to those on here? the amps are jbl gto's 2 1200.1.1 's and a 75.4 the head unit is a pioneer avh 6800 6 disk dvd with a pioneer deq-p8000 processor jl audio components xr570csi in the fronts and xr570 cxi in the rear dont ever buy them the suck! well the tweets do there fried in all of em only lasted three weeks. im looking to replace them just cant figure out what might hold up yet i like my highs loud. and im tring to find some 6.5" kick plates so i can have 2 component sets up front with rear fill in the back. i have 2 more of those mkIII 's going to make a new console for the rear with all 4 of them in it. I liked the way 4 of em sounded in my car loud! ha ha hope they sound as good in my truck 1/0 power cable with 2 150 amp circut breakers to the back wall of the cab into a 2 in 1/0 splitter with 4 2g outs going to my amps there is also a power acoustic 6 farad neon digital cap connected to the free 1/0 input on the splitter. quick question does anyone use welding cable for there power wires its about 2$ cheaper a foot and has the same strands or more in it than that pretty colored clear audio chit you buy in the stores and the rubber jacket is alot stronger against abrasion so that you dont get shorts and fires n stuff . just a suggestion to you people buying that stuff get it cheap at welding supply stores if you hide it no one will ever know. oh and will easily handle lots of current.
nah there junk thats why jl discontinued them. they cant handle jbl's punishment. RMS Power @ 4 Ohms: 104W x 4 @ 14.4V
THD @ 4-Ohm RMS Power: <1 %
Bridged RMS Power @ 4 Ohms: 284W x 2 @ 14.4V
Speaker Type Component - 2-way - passive
Max (RMS) Output Power 70 Watt
-3dB Frequency Response 48 - 25000 Hz
Recommended Amplifier Power 25 - 150 Watt
Sensitivity 90.5 dB
So they dont suck now?!?!? Still a little lost because after arguing that its not the XR's, now its a 180 degree swing.
Please dont bash something because you saw it in a sig, then find out its your install err "Fords design" that caused the issue.
Old Dec 9, 2008 | 02:41 AM
  #37
Low_e_Red's Avatar
Old Dec 9, 2008 | 03:12 PM
  #38
jrfonte's Avatar
well i own them and i will say what i want to about them how you like that.
Old Dec 9, 2008 | 04:03 PM
  #39
mSaLL150's Avatar
Old Dec 10, 2008 | 05:39 AM
  #40
Low_e_Red's Avatar
I personally think thats a bit of a cop out. But whatever Im done.
Old Dec 10, 2008 | 03:38 PM
  #41
jrfonte's Avatar
so i guess these should have lasted forever since i was overpowering them a little or was it because my amps dont have enough clean power to push them.\
__________________________________________________ _____mSaLL150
Senior Member Join Date: Aug 2006
Vehicle: 2004 Ford F150 4x4
last5oh_302
Senior Member Join Date: Jun 2007
Vehicle: 2005 Ford F150 4x4
The head tech at my dealer (or service advisor, whatever they're called) recommended to get the powertrain warranty. He mentioned that there's something on the tranny which is a fairly common thing to go wrong, and when it does, it expensive. Wish I could remember what it was. I'll be seeing hinm in about half an hour anyway, to get the recall done and the third brake light fixed, again. (high power carwash made it leak)
apparently im not the only one that has a leaky 3rd brake light there are a few others i doubt it was my install that make it leak and i do all my own work ill never take my stuff to one of those audio shops that think they know wtf there doing when most of em dont some do most dont. and yu get no satisfaction out of it knowing someone else did all the work and you take the credit.
Old Dec 10, 2008 | 10:43 PM
  #42
mSaLL150's Avatar
Well, if you had been around this site long enough, you might have followed my like 3 month install process. I deadened my truck before the install, and did some other cosmetic stuff for better sound quality. So yes, i did it all myself too. Except my amps arent shorting out and my speakers aren't exploding.
Maybe you SHOULD have taken yours to a shop...
Old Dec 11, 2008 | 04:05 AM
  #43
Low_e_Red's Avatar
Old Dec 16, 2008 | 04:37 PM
  #44
1bad86vmax's Avatar
Why don't people flush their amps on the back wall ? that way you don't see that Eyesore of wiring . I mean really , it would only take maybe a few extra hours . Let me ask you , what looks better in my install , the first picture or the second ?
Old Dec 16, 2008 | 04:59 PM
  #45
alexarizpe's Avatar
Ive always loved that setup i saw it awhile back on cardomain/sounddomain.
One of the reasons i did not do that is no one is going to see my amps, my seats dont fold down. i just wanted to organize it a bit. i admit i could do better hahaha but it works for now. maybe when i get sick of this setup ill do something like those pics
