Lowering a 4X4
Once again. Not asking for any opinion or advice, and looking under the truck is in no way measuring, nor is measuring a different year model relevant to the 15-16.
Getting deep into the red herring weeds, yes the 4X4 has a knuckle, but the knuckle combined with the actual spindle do make what is commonly referred to as the spindle assembly. Same would be for any spindle where the axle is removable regardless of whether the wheel is driven. Whether the actual spindle can be detached from the knuckle is irrelevant to the question of differences in geometry.
It's amazing how many are incapable of either saying "I don't know" or remaining silent.
Couldn't agree more
I did accept and thanked you for the one answer you gave. You, nor anyone else here answered the question of spindle geometry.
No sweat. Sorry to have interrupted the in depth discussions of gas mileage and leveling kits. I'll take the measurements when the time comes.
What part of "he did not answer my question" are you failing to understand? It was and remains a simple question: Is there a difference in spindle geometry?
Here we go again.
Now I know where the "stuck" part of your screen name comes from
So, back on topic and an attempt at adult communication. You are saying the ball joint to ball joint dimension, and the axle location and angle within that dimension are the same? Are you saying the steering arm length and position are also the same?
To be fair. I've been trying to help this entire time, if you choose not to read and understand (or try to understand) just because it isn't exactly the direct answer doesn't mean I'm not trying to help. bear with me here: Sometimes people need more information then they originally thought they needed to know, to get a better understanding of the answers given to them. Sometimes you need more than one puzzle piece to complete the whole picture
Several other people posted showing that I was trying to help and you just weren't picking up what I was laying down
Literally everything is common shared parts where possible (helps reduce production costs)
The 4wd stands almost 2" taller. (Via the longer struts)
There are slight changes of geometry in relation to the angles of the arms, and steering components. The physical length of the LCA doesn't change, but it sits less parallel to the ground in the 4x4 variant.
In theory you could "delete" front CV axles and swap 2wd spindles and the truck would stand exactly the same
Do we have a better understanding?
Anything else I can try and clarify?
