Hit a pothole and truck died. Won’t start back. Please help.
The older trucks had a fuel pump kill switch on the passenger side kick panel. It was to shut off the fuel after an impact to prevent fire. Old timers makes me forget the proper name for the switch. Look for a red button and push it to reset.
The newer trucks may not have it or perhaps it is in a different location. Anyhoo I hope that is it. I'm sure someone else will chime in to set one of us straight. Good luck.
The following users liked this post:
My Fuel Pump relay went bad, did you try switching it out with a different one.
Also the #27 fuse can show good and may not be making contact in the fuse box. Try a regular mini fuse instead of the mini low profile 20 amp in it.
You also still might want to check the FPDM, the one glc put up is the replacement, if it looks like the picture below it might still be the problem.
When I bought my 2013 with 43K on it it already had the Dorman on it, when the Dorman went out the local Ford dealer had the old style and is what they were trying to sell me so I bought another Dorman from Advance Auto.
