Manual on removing power seat switch?
Old 03-10-2016, 02:27 PM
preluder5's Avatar
read through a plethora of forums and did what some said worked in resetting the switch by leaning it all the way back but didn't work. I will be replacing my switch but would like to know if there's a diagram or manual or video out there on doing so? Where do I start and how do I remove the molding around the switch? Thanks fellas.
Old 03-10-2016, 06:04 PM
Augster's Avatar
I may replace the cover for the seat switch because mine is cracked along the crease.
I have an AllData service manual and when I get the time, I'll research the procedure and post steps.
Old 03-12-2016, 01:25 AM
svt2205's Avatar
From my 2011 Factory Service Manual. You can always buy a short term subscription at https://www.motorcraftservice.com/Home/Index and have access to all of the factory information you may ever need.
Seat Control Switch
Removal and Installation
NOTE:
For parts identification and location, refer to Seat — Exploded View, Front in this section.
1. If equipped, remove the adjustable lumbar ****.
• Adjust the lumbar until fully relaxed.
• Release the retainer and remove the ****.
2. Remove the side shield insert.
• Release the lower retainers and lift to release the upper retainers.
• Disconnect the seat control switch electrical connector.
• If equipped, disconnect the memory SET switch electrical connector.
3. Remove the seat control switch button.
4. If equipped, remove the recliner switch button.
5. Release the retaining tabs and remove switch.
6. To install, reverse the removal procedure.
Old 09-09-2016, 02:47 PM
cscot's Avatar
Did you ever get a chance to do this? I'm trying to figure out the power and ground wires for these seats and how to bypass the memory module.
Old 09-10-2016, 06:50 PM
Augster's Avatar
Not yet. Been too busy and have other priority projects for the truck presently.
Old 09-11-2016, 02:44 PM
cscot's Avatar
Thats Cool. Thanks for the response and good luck with your current projects.
Old 09-13-2016, 02:02 PM
cscot's Avatar
Hi Guys: see below
Old 09-13-2016, 02:04 PM
cscot's Avatar
Success !!!
(oops forgot the pic)Hi Guys: I managed to get this figured out. The diagram from wiring diagram SSCULLY (F150 Loaded Seat Wiring diagram ) helped imensly. I removed the memory module and related wiring from the drivers seat and wired the appropriate switch wires directly to the motors. Pug already had the 30 am fused hot wire in the male connector so was good to go after that. Passenger seat was a matter of finding the correct hot input and then setting up a fused hot connection from the battery and wiring it into the male end of the plug. Both are working great. Now to figure out how to wire the heat cooled functions to switches independant of a climate control system (which I don't have) pic of new seats installed below. Any help with the heat/cool wiring/switches would be welcome.
Attached Thumbnails Manual on removing power seat switch?-20160913_111114_resized.jpg
Quick Reply: Manual on removing power seat switch?
