Help! 2011 5.0 pings
Old 09-04-2012, 04:59 AM
foxer's Avatar
Tried several different gas stations. Happens mostly when shifting into second, light on the gas. Now if I stomp on it, no pinging. Tried all grades, and it gets better but does not go away. If I run 87 it REALLY pings. Any ideas (other than take to the dealer?). Oh yeah, uses about a quart of oil per 3k miles. 29k on it. Love the truck otherwise.
Old 09-04-2012, 05:46 AM
glc is offline
Take it to the dealer, that's what a warranty is for. Your oil consumption is considered normal.
Old 09-04-2012, 03:49 PM
jooman07's Avatar
Mine did the same for a while after I first got it too. I got a tuner and run the 93 octane tune and...no more pings. I think its something to do with the timing being off just a hair for the gas around here. Adjusted timing with the tuner and higher octane fixed the problem.
Old 09-04-2012, 06:40 PM
hammer40's Avatar
Try unplugging your VCT solenoids and see if the problem goes away.
My 5.4 does the same thing and is worse with a tuner.
Old 09-04-2012, 09:11 PM
glc is offline
I wouldn't mess with the VCT on a 5.0, it's a whole different system than was in the 5.4.
Old 09-05-2012, 12:13 AM
bansheerider's Avatar
My 2010 5.4 does this when going from 1st to 2nd gear. Sorry for the ignorant question but where are the VCT solenoids?
Old 09-05-2012, 09:53 PM
jooman07's Avatar
bansheerider - http://blaggers.info/?p=88
i know its older but maybe that'll help you out.
foxer - i would just try running a higher octane for a while and see how that helps. Redline has a synthetic additive that might do you some good too. http://www.redlineoil.com/product.aspx?pid=80&pcid=12
i run that every 3000..
Old 09-28-2012, 03:11 PM
Blue07STX's Avatar
I had a ping on hard acceleration (passing on highway/in town traffic) while running 87 ocatne E10 Shell gas. It went away when I switched to 87 octane E10 Conoco/Phillips 66 gas. I have also tried Shell 93 octane and have no issues with ping/pre-detonation.
I run MC 5W20 Syn Blend oil and have zero issues with oil consumption between 6,000 mile service interval's.
Old 09-28-2012, 08:51 PM
JustA5.0's Avatar
could try E-85 and see what happens
Old 09-28-2012, 10:07 PM
DewserB's Avatar
TRUCK OF THE YEAR 2013
I imagine that might make it worse.
Old 09-29-2012, 05:16 PM
JustA5.0's Avatar
I figured it wouldnt. average E-85 is 102 octane rating.
Old 09-29-2012, 06:48 PM
blueovelboy's Avatar
i read on a norther site where the ping went away with to cans of sea foam being ran threw with one tank of gas. ill find it and see if i remember right
Old 10-02-2012, 08:08 AM
OnBelay's Avatar
Or, in English: "I read on another website where the ping went away with two cans of Sea Foam applied through a single tank of gas. I will find it and see if I remember correctly."
Of course, we should all just assume he meant to call himself "Blue Oval Boy". To call himself an "Ovel" would just be awkward:
ovel [ˈɒvəl], n (Non-Christian Religions / Judaism) Judaism a mourner, esp during the first seven days after a death See also shivah, [from Hebrew]
Old 10-02-2012, 08:14 AM
DewserB's Avatar
Just want to clarify to the lookers on that this feller ^ is NOT me operating under an assumed identity.
Old 10-02-2012, 09:32 AM
shortride's Avatar
There must be something wrong with my truck. The oil level on the dip stick is always on the full mark at oil changes.
Quick Reply: Help! 2011 5.0 pings
