Hot tire/rubber/burning smell from hood area.
Any chance you splashed anything up near the block. Ive smelled that before when taking truck on the beach or thru a muddy puddle.
It occurs on moderate temperature (45-55*F), dry day's after 30 minutes of driving. No smell when it rain's.
Check to see if you have a brake caliper stuck. It's usually quite similar to an electrical smell.
Nothing appears to be dragging. It is not a brake or clutch smell. It actually smell's like rubber from a tire.
I've had this smell on my last two Plats. In both cases it went away and at one point I did find a piece of the harness tape had fallen down next the exhaust. Check to make sure none of the factory harness tape has fallen down there. To clarify, I'm not talking about the permanent tape that wraps the electrical system, but the tape you see as a left over of the manufacturing process, it must be what holds the wire looms together as they are building the truck. You'll find it everywhere, under the seats in the interior, hanging off the wiring system throughout the truck, etc.
OK, here is the smell source....It is the plastic tubes connected to the turbos on the EB. They go through a final "seasoning" when heat cycled. mine had this for the first 5-6000 miles. Just use the turbos real hard until the plastic "sets", then it will go away. the hotter you get them the sooner they will cure.
I also have a left caliper stuck
Hi FALLENF96! I have the same problem, is there a way to fix the caliper instead replace it? What make's the caliper to back to it's home position?
artgarcia - Hi FALLENF96! I have the same problem, is there a way to fix the caliper instead replace it?[/i]
A sticky caliper could be that the slides need to be lub'ed | the piston is pitted, corroded, etc., or the seals are cracked, leaking, etc.. If it's the piston | the seal, the caliper would need to be replaced.
