Hot tire/rubber/burning smell from hood area.
Old Dec 22, 2011 | 12:16 PM
Blue07STX's Avatar
I've experienced a hot/rubber/burning smell coming from the grill area after driving about 35 minutes at 55-60 mph. I have performed a visual inspection under the hood, under the chassis, at each brake, tires, transmission and exhaust.
I can find no melted wiring covers, burnt tape, fluid leaks or anything out of the ordinary.
I currently have 11,660 miles on the odo. Has any other 5.0L owner experienced this lately or at all?
Thanks, James
Old Dec 22, 2011 | 04:42 PM
JC10380's Avatar
Belt Issue?
Old Dec 22, 2011 | 04:48 PM
Gallows's Avatar
My clutch fan on my 06 was giving off a similar smell when it was ready to crap out. It took a few days to get the odor out of the vents after it was replaced.
Old Dec 22, 2011 | 05:31 PM
2011's have efans....
Old Dec 22, 2011 | 07:34 PM
High-ster's Avatar
Originally Posted by JC10380
Belt Issue?
That is what I'd suspect, too.
Back in the day, maybe a clogged PVC valve.
Old Dec 22, 2011 | 07:54 PM
I would look at a failed idler pulley
Old Dec 22, 2011 | 10:46 PM
Blue07STX's Avatar
Belt Issue?
I checked with engine running and engine off. No burnt or frayed belts noted. Pulley's appeared to rotate properly.
I did not notice any weird smell this morning or afternoon. Although, it did rain most of the day.
Old Dec 23, 2011 | 12:34 PM
STANGBANG's Avatar
Mine has it too. Can't figure it out.
Old Dec 23, 2011 | 12:39 PM
Blue07STX's Avatar
How many miles on the odo? Mine started around 11,600 miles.
Old Dec 27, 2011 | 07:29 PM
jbear223's Avatar
Hmmm, I get this smell also. More of a plastic smell though. usually after a 2-3 hour drive or after an hour or so of slow 4x4 action.
Old Dec 28, 2011 | 10:47 AM
2004f1505.4x4's Avatar
I've noticed it on my 5.0 too, cant seem to find anything
Old Dec 29, 2011 | 11:32 AM
ruffn-it's Avatar
Any chance you splashed anything up near the block. Ive smelled that before when taking truck on the beach or thru a muddy puddle.
Old Jan 2, 2012 | 04:06 PM
jbear223's Avatar
The smell i encounter is generally after the truck was driven hard, as in fast acceleration or heavy 4x4 use. Maybe exhaust manifolds get hot enough to start melting some plastic but I haven't put any wires too close.
Old Jan 2, 2012 | 06:18 PM
WhiteFX4's Avatar
Check to see if you have a brake caliper stuck. It's usually quite similar to an electrical smell.
Old Jan 4, 2012 | 09:28 AM
Schulzee's Avatar
I noticed this smell last night, very strong plastic or rubber burning smell. I need to take my truck in anyway because it is leaking transmission fluid after spirited driving or lots of highway use.
