seat covers and bed lights
Old Aug 20, 2010 | 11:39 PM
2004Shadow's Avatar
precision fit seat covers
front:
Rear:
Bed Lights:
Switch
Lights at night:
Old Aug 21, 2010 | 12:25 AM
05BlackFX4's Avatar
very cool...what lights did you put in the bed?
Old Aug 21, 2010 | 12:34 AM
2004Shadow's Avatar
a 12 inch led strip from the autozone. like 8 bucks
Old Aug 21, 2010 | 01:01 AM
Woods-Rider's Avatar
Looks good, but I would have just hooked them up to the existing cargo light so you didn't have to put in the switch. It keeps your dash looking cleaner and one less switch you have to hit to get light back there. This may be something I'll have to do if I ever get bored one afternoon. For $8 per side you can't really go wrong.
Old Aug 21, 2010 | 02:01 PM
Gir's Avatar
Gir
Curious, what is the easiest way to power the bed lights. Do I need to run my own wires and where is the best conduit to do so?
Old Aug 21, 2010 | 06:08 PM
2004Shadow's Avatar
I already had a fuse panel installed that I hooked it up too. As posted above you could also just splice into the cargo lights.
Old Aug 21, 2010 | 08:12 PM
juneau76's Avatar
Pretty cool.
Old Aug 22, 2010 | 05:49 PM
joshn's Avatar
The lights look like they do a pretty good job thanks for the post.
Old Aug 23, 2010 | 10:03 AM
sharper4's Avatar
I made a How-To post on the other forum called "Recon Bed Light Install Guidelines" which might help with connecting bed lamps to the cargo light. You're looking for a gray wire with a purple stripe inside the driver's kick panel.
Old Aug 23, 2010 | 01:02 PM
heybeermantx's Avatar
Originally Posted by Woods-Rider
Looks good, but I would have just hooked them up to the existing cargo light so you didn't have to put in the switch....
Unless things have changed, which I haven't checked yet, when you roll up to turn the cargo light on, it will also turn on the inside dome light. There are times that I would rather be able to turn on the cargo light to check the cargo while going down the road, and with the dome light on also it sometimes makes it tough to see.
I'd rather have this seperate switch.
Old Aug 23, 2010 | 04:49 PM
waavygravy's Avatar
Where did you get those seat covers? do you have a link for them?
Old Aug 23, 2010 | 11:38 PM
2004Shadow's Avatar
http://www.precisionfit.com/
the fit is great. nothing loose. have the same brand on my wrangler. love them both
