Anyone changed the map/dome lights to LED's?
Old Dec 28, 2010 | 08:53 AM
  #106
Pig9r's Avatar
Anyone tried these yet? I am thinking of ordering from them.
http://cgi.ebay.com/ebaymotors/ws/eB...t_11998wt_1167
Old Dec 28, 2010 | 11:07 AM
  #107
pwheels's Avatar
I was thinking about ordering those as well. It's a bummer they don't come with the third brake or taillight (brake and turn). Then I would be sold. I'm thinking about doing a set up from V-Leds so I can get colors to match it all
Old Dec 28, 2010 | 11:53 AM
  #108
OGTerror's Avatar
$90!? For half that price you can get a pair of universal LED at any auto parts and get the same effect.
I just did this last week to my expedition. The kit includes the 5 OE adapters:
For some reason or another the kit I bought did not include the socket I needed so I did this:
So I went from this...
To this:
Old Dec 28, 2010 | 03:04 PM
  #109
murderout's Avatar
09 fx4
Old Dec 28, 2010 | 05:42 PM
  #110
ruffn-it's Avatar
Well the ebay kit does include led cargo lights and reverse light bulbs.
Old Dec 28, 2010 | 11:21 PM
  #111
DarkShadowSTX's Avatar
C'mon guys, order from Vleds or some other reputable site, not Ebay. Looks like a bunch of BS to me when I look at that Ebay link. Scroll down, it has the reverse light as 2- 9 led bulbs and then also 2- 68 led bulbs. WTF? The description also does not even tell you the bulb replacement #s so you don't even know if they are the correct ones. My .02
Old Dec 29, 2010 | 12:40 AM
  #112
josh34's Avatar
^ agreed...
Old Dec 29, 2010 | 01:34 AM
  #113
StickyF250's Avatar
Anyone got an idea on vanity light bulb removal? Don't feel like breaking the bulb in the socket.
Old Dec 29, 2010 | 02:31 AM
  #114
Kroezer95's Avatar
....Pair of pliers worked great for me...those little bulbs are stronger than they look
Old Dec 29, 2010 | 02:33 AM
  #115
StickyF250's Avatar
Yeah tried needle nose and reg. Neither wanted to pull bulb without giving me the impression it was going to explode under the pressure.
Old Jan 3, 2011 | 06:19 PM
  #116
b10751's Avatar
Just received my LED's from v-leds. 2010 supercrew. changed out map lights, but how do i get the dome light cover off? Do you insert a small blade screwdriver in the slot that is on the clear plastic cover and pull? Don't want to break anything..
Old Jan 4, 2011 | 09:39 PM
  #117
Pig9r's Avatar
Just did mine tonight and had the same delimna. I used a wide blade screwdriver and put a piece of plastic between it and the headliner. I pried down with one hand and pulled down with my fingers on the other side. It takes quite a bit of force as the whole think snaps together in several places and there is no indication that it is coming off.
I went with VLeds for the map lights, dome lights, cargo lights and license plate lights. I like the results. Thanks to all!
Old Jan 5, 2011 | 06:16 PM
  #118
bansheerider's Avatar
How do I know which bulbs to buy from v-led? They have tons of bulbs to choose from. I have a 2010 FX4 and want to replace the map and dome lights with white leds. Thanks!!
Old Jan 5, 2011 | 09:22 PM
  #119
First of all: https://www.f150online.com/forums/ap...de-thread.html
Second:
2010 FORD F150
High & low beam headlamp
H13 (9008)
H13ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H13XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
Parking light
3157A
3157NALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
3157A
Rear turn signal
4057
4057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
4057
Stop light
4057
High mount stop light
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Fog/Driving light
9140
License plate
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
3156
3156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
921
Front sidemarker
194
Rear sidemarker
4057
Map light
194
906
906LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
578
578LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
6411
6411LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Trunk/Cargo area
921
Old Jan 5, 2011 | 10:25 PM
  #120
Originally Posted by DarkShadowSTX
Hey thanks for the info. I went to order the dome lights and it looks like they are out of stock Now I have to wait a few weeks to order.
