HID's for my 09
Old Mar 5, 2009 | 03:06 PM
smkeater's Avatar
HID's for my 09
I just installed Xenonlinks's HID kits for my headlights (bi-xenon) and fogs. All went well except for a minor bulb problem that was rectified quickly by William. It was easy plug and play setup, I just had to flip the diode/resistor for the headlights for the highs to work. I cant wait to drive tonight with them. Sorry for the pic its a little sunny out. I will get a better pic tonight!!
Old Mar 5, 2009 | 03:11 PM
ChromeZ's Avatar
CONGRATS!!!! u are the first with HIDs on the 09s
bananas fo chu!
night pics of cut off and road output please
Old Mar 5, 2009 | 03:22 PM
05_sprcrw's Avatar
congrats they are awesome you will love them. Good looking truck did you get 6000K?
Old Mar 5, 2009 | 03:33 PM
smkeater's Avatar
Forgot about that part!! Yes I did 6000k.
Old Mar 5, 2009 | 03:42 PM
blackjack8900's Avatar
Are the 09's still H-13 and H-10?
Be sure to get some night pictures.
Old Mar 5, 2009 | 04:02 PM
ibcop's Avatar
How much was the kit? Link?
I bet it'll look awesome!
Old Mar 5, 2009 | 04:17 PM
smkeater's Avatar
Yest they are H13 and H10-9140
Old Mar 5, 2009 | 04:22 PM
smkeater's Avatar
The headlights were $135 bi-xenon 6000k and fogs were $100.Free Shiiping
http://www.xenonlink.com/
Call (886)-857-0005 ask for William and mention F150online and you will get a discount for a member. I had a mnior problem with a bad bulb and all was rectified by William quickly.
Old Mar 5, 2009 | 06:26 PM
SportTractoF150's Avatar
Are the fogs H10-9140's or H10-9145's? I can't seem to find the 9140's.
How was the install? Easy? Hard to find places to mount the ballasts? Easy to get into the lights?
Old Mar 5, 2009 | 07:24 PM
ChromeZ's Avatar
the numbers i do not remember.
The install is easy. Bulbs fit in just as the stock ones do push and twist.
The wiring is where a little but of know how comes in. battery connector, 2 grounds (per set), plug and play makes it easy (retro solutions or xentek i believe is plug and play as well).
On my 07 the fogs were very simple to mount there was an opening on the frame connecting the bumpers. I mounted the headlights with double sided tape to the side of the headlight itself. Nice little spot to put it!
Old Mar 5, 2009 | 09:39 PM
ChromeZ's Avatar
its dark! where r the pics!!!!!
Old Mar 6, 2009 | 01:12 PM
cdiddy4224's Avatar
i second the above post
Old Mar 7, 2009 | 07:26 PM
Monkey#39's Avatar
intersting mod... so no wire slicing? is it just like an adapter you plug into the stock bulb socket
need soom pics!
Old Mar 7, 2009 | 07:48 PM
ChromeZ's Avatar
depending which kit you get YES no wire splicing. there are a couple companies out there that are "plug-and-play" u still have ballast and all of course but no splicing wires. Only thing is im not sure if you still have to ground the fuse like u did in the 04-08. I would assume so. (Bambi mod - allows to run fogs and bright lights as well as give you your high/low beam functions)
Old Mar 7, 2009 | 11:48 PM
FX4life's Avatar
Very cool Its awesome to see you guys already modding your 09's
