Mec says wheel hub is causing braking issues. Should i buy from amazon/rockauto?
So I'm in my truck and when i try to stop at a light the pedal goes to the floor. Pumping didn't work. I had to go full Flintstone to bring it to a stop.
It happens occasionally but enough to make me not drive her anymore.
I took it to the shop and the mec lifted it in the air and shook the tire back and forth. He said it was my wheel hub was going bad and the braking issue was due to the ABS sensor not getting signal correctly.
Ok got that.
My mec says if I get it he will install it. Now I'm off to find a wheel hub. I found a few on amazon and several on rockauto.
So my question to the wise members of this forum is which front wheel hub should I get?
I have an 05 4wd navigator.
Ok got that.
BUT it sounds to me like there's more going on than just a wheel hub and/or bearing! Other than a failed master cylinder or MULTIPLE brake failures, your brake pedal should NEVER go completely to the floor! US made automobiles have LONG used a DUAL hydraulic braking system to prevent things like that from happening. Even with the complete loss of fluid, a wheel, the bearings, a wheel cylinder, etc you should still have full braking capacity with the other brake circuit. I think you need to take a critical look at the entire braking system including that at each wheel.
Gotcha,
Found 2 Motorcrafts on rockauto. Does the $100 difference make a difference?
MOTORCRAFT HUB275 - Part #6L1Z1104E - Front; 4WD; OE Design; w/ Bearings and Races for 192$
Or
MOTORCRAFT HUB23 - Part #6L1Z1104DA - Front; 4WD; OE Design; w/ Bearings and Races for $291
Or
haha i hear you but i'd really like the opinion of someone more experienced than myself.
I see a difference between spending money and wasting money.
I could buy an interstate, a diehard and an optima battery and they all perform the same and last just as long. One of them is just much more expensive.
The descriptions on the items are the same. Which would you guys buy?
Ok got that.
Ok got that.
+1 on rockauto. I've been ordering parts from them for ... a decade? Amazon is pulling on them though. Rockauto is still my first source for finding the CORRECT part number, but add it to the cart and calculate shipping. After that I shop around based on the "shipped" price. The last couple purchases I did through Amazon because it saved me around 15% off my purchase price and I had guaranteed 2 day shipping. FYI, that was for some KYB struts for a different car.
That said, I hope rockauto never goes away. I use their site at least once a week for random stuff like checking what light bulb a coworker needs for their car to figuring out what sort of ignition system another coworkers truck uses.
OP,
On your hub question, I would buy hub275. My googling lead me to this: http://www.fordparts.com/Commerce/In...px?part=HUB275
Looks like 23 is the original design, 275 is the new and hopefully improved one. Also cheaper for some odd reason.
OP,
