06 f150 triton spark plug problem
Of course there is a problem with my triton plugs, however, I've replaced 7 of 8 plugs and broke 3 in the process. Bought the tool and that is all good. However, the back passenger side plug has some kind of something in the hole surrounding the plug that is preventing the socket to reach the hex section. Has anyone seen this and/or know how to remove it?
I would try scraping it dry before you use any liquids on it. Then blow it out real good with a compressor. If you don't have a compressor then go buy a can of air (not a joke) at Staples, like they use on computers. Just make sure it is clean because as soon as you remove the plug the loose stuff will drop into the cylinder.
