weight for snow
weight for snow
how much weight does everyone put in the back of their trucks for snow? mine is an 08 screw 5.5 with a topper. I was thinkin about 200 lbs
oh yeah, its 4wd with all season tires, does fine now but just wondering if it would help me stay out of 4wd.
2WD here w/ A/T tires and I can get around without the weight in the back, but starts take a good bit on unsanded ice/snowpack. I usually throw 6 - 50lbs sand bags in the bed (300lbs) and that's good enough to make a significant difference in traction.
Same but I use 2 spare tires plus 3 80lb backs of quick cement
None my limited slip plus I keep fairly new tires on truck or get new ones near winter if they are past 40k on them. I just have a 4x2 truck and haven't had any problems in the snow we get in the middle TN area over the winters I had this truck.
I can see a single cab and maybe a 2wd Supercab needing weight, otherwise I see it unnecessary. Supercrew cabin is much heavier to begin with and does weigh the back down some.
The Supercrew isn't markedly heavier than a Scab. I promise, I had to work to get up in my driveway with the 2WD Screw when we got ice/snow a few weeks back. Granted I was on tires with 60K+ on them a the time, but tread doesn't help much on ice/sleet. The issue is that there is negligible weight over the rear axle in any truck, so an extra 300lbs sitting right on top of the driven wheels makes a ton of difference.
